Ford Yt16h Rollers
3 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted August 18, 2012 - 04:29 PM
anyone know what size the front and rear rollers are for the deck?
i took the deck off today to see why the belt started to shred when i was mowing the other day. i found what caused it and i fixed it. there was a front pin that holds the deck on and it was to long so i cut it to length and welded a washer on the one end. then i took a old tie rod and made a bar for the rear roller when i get one.
here is a pic of the rod i made for the roller.
and here it is in place
#2 KennyP ONLINE
  • 38,271 Thanks
  • 45,877 posts
Posted August 18, 2012 - 04:48 PM
Not sure on the YT as to what size the rollers are. I used boat trailer rollers on mine. What size is the shaft through them? OD? New Holland has new ones for about $25 each.
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted August 18, 2012 - 09:25 PM
That looks like it would take the same "boat rollers" they come as 2-1/2 Xx 12" ans can be obtained from several boat dealers.
I ordered mine from Trailer Parts Superstore. Look for YATES Boat Trailer Straight Roller #12243-4P Only $12.00 each.
#4 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted August 23, 2012 - 12:50 PM
sorry it took so long to answer this. the shaft i made is 1/2" on the rear. the front isnt the right one so ill find a 1/2" rod and make one for the front also.
