Any Ideas Of What's Happening To My Fuel ?
32 replies to this topic
#31 OldBuzzard ONLINE
OldBuzzard
  • 7,124 Thanks
  • 4,823 posts
Posted August 17, 2012 - 05:25 PM
I wish all fuel tanks had a low spot, or "sump" for the water & alky to settle into, along with a petcock to allow easy draining of the stuff! Having the fuel valve in the bottom of the "main floor" of the tank, above this sump.
Yeah, that would be a good idea.
I know that light aircraft all have a setup like that.
Back when I owned a Cessna 140, part of the preflight inspection included opening each petcock (it had a tank in each wing) and draining a bit of fuel to check for water.
The other 'cardinal rule' was that you always fueled up AFTER each flight to minimize condensation.
#32 olcowhand ONLINE
  • 43,171 Thanks
  • 32,012 posts
Posted August 17, 2012 - 06:42 PM
That's the good thing about the older engines with a glass bowl filter/water trap. At a glance you could see water in the bowl.
#33 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted August 17, 2012 - 06:56 PM
I had a McCulloch generator from the 70's with a 7hp Briggs that had one of those glass bowls on it. Not only could you see the water or other debris you could deal with it in a couple of minutes. It seems fuel related issues are one of the most common sources of problems seen here.
