Fabricating Implements
plans dimensions etc.
14 replies to this topic
#1 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted August 13, 2012 - 08:39 PM
I am looking for some plans, and dimensions so I can fabricate implements for my MTD.
I assume the 3 point is a type 0? how heavy of a harrow could I pull with this 16 hp Briggs, after I get it running of course . Any idea of the weight of the heaviest implement?
  • 14,889 Thanks
  • 15,514 posts
Posted August 13, 2012 - 08:46 PM
I have never tested the max lifting of my 990, but I would think 300lbs. should be be no problem..
#3 caseguy OFFLINE
  • 1,629 Thanks
Posted August 13, 2012 - 09:00 PM
Just wondering if your unit is manual or hydraulic lift? That will make a big difference in how much you'll WANT to lift!
  • 14,889 Thanks
  • 15,514 posts
Posted August 13, 2012 - 09:08 PM
The MTD 990's have hydro lift Steve.
#5 caseguy OFFLINE
  • 1,629 Thanks
Posted August 13, 2012 - 09:22 PM
Thanks Brian. I wasn't aware of that. Most of my Horses are manual lift and 300 Lbs. sounds like a dislocated shoulder to me :laughingteeth: That shouldn't be a problem with the hydro lift though!
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 13, 2012 - 10:09 PM
Are you talking disc harrow or tooth harrow? The Brinly sleeve hitch disc harrow is pretty light and I would think you could handle a double?
I've also seen guys use a Farmall Cub disc behind a GT and a single gang probably weighs more tha a double gang Brinly and would pull harder.
I have a couple 4' or 5' spike tooth harrows(can't remember which) one unweighted and one with a couple cement blocks tied on and can pull either with my 318 or Murray yardking( I get some wheelspin with the Murray and the weighted one in loose dirt). these are just drug and not on a mounted lift frame.
Overall it's going to depend a lot on how your 990 is weighted/tires and ground conditions.
Edited by JD DANNELS, August 14, 2012 - 08:05 AM.
#7 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted August 14, 2012 - 03:44 AM
This is how I modified a Cub disc to pull behind my Cub Cadet.
  • JD DANNELS and Sawdust have said thanks
#8 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted August 14, 2012 - 04:23 AM
Amigatec, that was a very nice fabrication on the disc.
#9 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted August 14, 2012 - 04:42 AM
I need to rework the axle, the angles are off a bit.
#10 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted August 14, 2012 - 04:47 AM
My father-in-law always told me that you aren't stuck as long as the wheels are turning. Great job on the lift.
Edited by GTTinkerer, August 14, 2012 - 04:47 AM.
#11 KennyP ONLINE
  • 40,983 Thanks
  • 47,148 posts
Posted August 14, 2012 - 05:04 AM
That's a great lift. Very good idea!
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 14, 2012 - 08:03 AM
Aggatec that's a neat video and carrier for the disc. Thanks! Seeing that someone has already executed an idea that has been bouncing around in tne back of your head. Assures me that I'm not totally nuts afterall.(smiley is not working?)
#13 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted August 14, 2012 - 11:37 AM
Sweet job Amigatech, thanks for the inspiration.
On the Lincoln Electric web site there are some project books I am thinking about buying. In them are some ag equipment I can scale down
  • cookiemonster said thank you
#14 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted August 14, 2012 - 11:49 AM
There's a projects page on Lincoln Electric? Can't find it... Where?
#15 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted August 14, 2012 - 02:21 PM
Actually, these are the books that I was talking about. There is a section in each book with farm and ag implements. You might find them cheaper through bookfinders.com, or amazon, even the library may have them for loan.
http://www.jflfounda...com/default.asp
Also here is a page with some reasonable reference material, the miller site is more fun
http://www.lincolnel.../resources.aspx
Also tagged with one or more of these keywords: plans, dimensions, etc.
