Extra Decks,how Do You Store Yours?
23 replies to this topic
#16 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 15, 2012 - 06:48 PM
I took pics but my iphone has to recharge before I can get them uploaded.
  • IamSherwood said thank you
#17 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted August 16, 2012 - 04:46 PM
phone is charged.. ..... .... .... pics???? .... .... .... ...
#18 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 16, 2012 - 06:14 PM
ImageUploadedByTapatalk1345158833.234904.jpg ImageUploadedByTapatalk1345158853.105636.jpg ImageUploadedByTapatalk1345158871.186478.jpg
  • IamSherwood and pigsitter have said thanks
#19 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 16, 2012 - 06:21 PM
The shed has 2x6 stud framed walls unfinished on the inside. I took 2x4s and 2x6s and of course an air nailer and mitre saw to build it. I set the mitre saw to 10 degrees (saw being at 80 degrees I think) and shopped the 2x6s and 2x4s the same. Picking two studs that fit the deck widths best I cut the blocking and arms to fit the deck heights and depths. The arms do slope for better cantilever effect, so don't skip the blocking! Then air nailed to existing studs, pretty simple, and a two person job for air nailing the arms in place. It has been about 2 years and still doing well.
Edited by wvbuzzmaster, August 16, 2012 - 06:23 PM.
#20 ShelbyGT550 OFFLINE
ShelbyGT550
  • 16 posts
Posted August 16, 2012 - 07:49 PM
No one wants to see mine, trust me, They weigh a ton so I dragged them with the tractor to the side of the house and tipped them on their side, of course the side that faces out has to be the inside -_-
#21 IamSherwood OFFLINE
  • 8,395 Thanks
Posted August 16, 2012 - 08:23 PM
Thanks Casey.
That just gave me an idea.
Do you man handle them up there?
#22 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 16, 2012 - 08:29 PM
Thanks Casey.
Ya, I should have mentioned that you do need a second person to lift them up there. I supposed you could use a chainfall and wrestle them. One thing is do not build higher than you and your most likely helper can lift the lightest deck.
#23 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,229 Thanks
  • 1,083 posts
Posted August 16, 2012 - 09:54 PM
That's an easy one my oldest daughter is my regular "volunteer" and we're the same height :laughingteeth:
Thanks for some ideas Casey :thumbs:
Edited by pigsitter, August 16, 2012 - 09:55 PM.
  • wvbuzzmaster said thank you
#24 mjodrey OFFLINE
Posted August 17, 2012 - 04:54 AM
I store mine over the winter on edge up against the wall of the garage. I use a ratchet strap around a screw into the stud to hold it up.
That is about the same thing I do.
