Machine Work Needed
8 replies to this topic
#1 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted August 12, 2012 - 09:02 PM
I was wondering if anyone reading this has the equipment to resurface the pressure plates on my cub? Thought I would ask here , b4 I box them up and send them to brian mille Ir or somone like that. I've got 2 sets I would like to have done. If your intrsted let me know, I dont have the tools to do it. Still need a driveshaft made up also, thanks
#2 Grumpy OFFLINE
Grumpy
  • 732 Thanks
  • 619 posts
Posted August 13, 2012 - 03:57 AM
I can, but maybe someone closer will be able to do it without shipping. You can call 8one2 4five3 98three1
Edited by Grumpy, August 13, 2012 - 04:01 AM.
#3 mjodrey OFFLINE
Posted August 13, 2012 - 04:34 AM
I too could do it,but am also too far away.
#4 KennyP ONLINE
  • 40,047 Thanks
  • 46,736 posts
Posted August 13, 2012 - 04:53 AM
I wonder if a local shop that does engine work couldn't do that. It would save the shipping charge!
#5 JDBrian OFFLINE
  • 9,635 Thanks
  • 14,156 posts
Posted August 13, 2012 - 05:35 AM
I'd try local machine shops that specialize in automotive work. That might save you some time and money.
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,858 Thanks
  • 10,037 posts
Posted August 13, 2012 - 06:29 AM
What do tractor mechanics in your area do?
#7 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted August 13, 2012 - 12:37 PM
All I do with those is put then into a metal turing lathe until you get a smooth flat surface.
Any welding shop should have a turing lathe.
If you have to take alot of metal off you might have to add a flat washer behind you pressure spring to obtain the correct pressure for the clutch.
#8 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted August 13, 2012 - 01:12 PM
im sure that someplace in Cincinnati is a machine shop that could do this. would it be able to be turned on a brake lathe ?
im not sure what it looks like so if you could post a pic i could tell you.
#9 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted August 13, 2012 - 01:56 PM
well A while back I talked to a guy that works on tractors mostly,has a machine shop in the basement of his shop,he was telling me he didnt h ave a way of doin it, ,I'm thinkin he just did not want to mess with it,cause I've been in the basement before and he does have the equipment to do just about anything he wants. there kinda strange,As far as having them shipped, I really dont mind paying,I could fit them in a flat rate box.
