Running Issues
6 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted August 12, 2012 - 01:05 PM
so yesterday my 126 ran out of gas while i was pushing some gravel around now it wont stay running any ideas on whats wrong? also before this happened while pushing dirt it would start to stall inless i hit the clutch and readjusted the throttle. im guessing its carb related or has to do with derbris
#2 mjodrey OFFLINE
Posted August 12, 2012 - 01:06 PM
Yes,probably picked up some dirt out of the tank when you ran it dry.
  • 14,730 Thanks
  • 15,470 posts
Posted August 12, 2012 - 01:09 PM
Would say that you have got some trash in the carb or tank. Do you have a inline fuel filter on it?
#4 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,230 posts
Posted August 12, 2012 - 01:40 PM
I agree with them, when it ran out it pulled some gunk into the carb. Clean the carb, flush out the tank good and replace any fuel filters. If you don't have a filter put one in.
  • jd.rasentrac said thank you
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted August 12, 2012 - 01:42 PM
As Brian said, it's good to use a inline fuel filter and maybe clean the gas tank, because after some time you'll find (condensed) water at the ground that will corrode the inner tank.
EDIT: Seems you were a little bit faster, Ryan :beerchug:
Edited by jd.rasentrac, August 12, 2012 - 01:43 PM.
#6 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted August 12, 2012 - 02:45 PM
thanks guys there is no inline filter and the carb did have some sediment in it. im goona clean the sediment bowl on the bottom of the carb next just to make sure there no more gunk.
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 12, 2012 - 05:23 PM
While you are cleaning the carb I would put a fuel filter in the fuel line.
  • backwoods said thank you
