Transaxle Gasket And Oil 2 For Wheeler
13 replies to this topic
#1 VSTROM803 OFFLINE
VSTROM803
  • 371 Thanks
  • 338 posts
Posted August 11, 2012 - 08:28 PM
Hi all,
I'm going to split the cases on my 5756 and replace the axle seals. I'll have to make a new gasket and was wondering what type/thickness gasket material I should get for it. Also, what is the recommended oil for the tranny? Thanks!
#2 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,409 posts
Posted August 11, 2012 - 11:08 PM
In the transaxles I prefer (at least for DB's) to use SAE 30 non-detergent. However, if you have leaky seals a heavier weight may be beneficial such as 80w-90 gear oil.
#3 VSTROM803 OFFLINE
VSTROM803
  • 371 Thanks
  • 338 posts
Posted August 12, 2012 - 04:22 AM
I have the 80-90 gear oil in it now and it still leaks like a sieve. I guess the seals are just rotted out.
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted August 12, 2012 - 04:39 AM
It calls for 30 wt.
#5 VSTROM803 OFFLINE
VSTROM803
  • 371 Thanks
  • 338 posts
Posted August 12, 2012 - 05:05 AM
Thanks guys, Anything special about the gasket paper? Thickness maybe?
#6 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted August 12, 2012 - 05:38 AM
I need to do that to my Super Power, but it's not leaking that bd yet.
#7 oldmanskipper OFFLINE
oldmanskipper
  • 9 Thanks
  • 14 posts
Posted August 12, 2012 - 11:28 AM
Hey Mike,
Ithought I would just see what the old material looked like after I got the diff. apart. If it's thin I'm going to use a heavy poster board and if it looks thicker I'm going to use a thin cork. I found some in the shelving dept. at Lowe's that is wide enough. After I replace the seals I'm going to coat the small half of the diff. with seal-tex and lay it down on the material to dry while I trim around the outside and after it sets a bit I'll trim out the inside and open up the bolt holes. Now I think that will be easier than trying to trace one out from the old seal but I'm open to any ideas from anybody else so help me out people if I'm wrong. Once all this is done I would stick with the 30 weight oil since that is what it calls for. Good luck and keep me posted on your progress.
Thanks, Skip
#8 VSTROM803 OFFLINE
VSTROM803
  • 371 Thanks
  • 338 posts
Posted August 12, 2012 - 11:45 AM
I've never made a gasket from actual gasket paper. I'm just a little concerned about thickness due to the possibility to changing tolerances. I'm probably just reading too much into it. I've already taken apart an extra transaxle I have for a dry run. It was so rotted out it didn't even have gasket material in it.
I had hoped to replace the seals from the outside but, they're just too stout to get out like that.
By the way check out my fresh painted disc harrow in my photo gallery.
#9 VSTROM803 OFFLINE
VSTROM803
  • 371 Thanks
  • 338 posts
Posted August 12, 2012 - 12:38 PM
Skip,
You could lay your material on the case and lightly tap around a bolt hole with a small ball peen hammer to cut it out then put in a bolt
in for alignment. Then stretch the material out good and do the same on another one. Work your way around. The sharp edge of the case should do the cutting. Then go around the inner and outer edges to completely cut it out.
#10 Virginia Mike OFFLINE
Virginia Mike
  • 16 Thanks
  • 30 posts
Posted August 13, 2012 - 06:35 AM
I don't think I would split the gearcase to remove the axle seals. You can drill a small hole in the and pull them out with a dent puller with a screw tip.
If I did split the case, I would re-seal it with RTV silicone and avoid the trouble of making a gasket.
#11 VSTROM803 OFFLINE
VSTROM803
  • 371 Thanks
  • 338 posts
Posted August 13, 2012 - 08:27 PM
Yeah, thought about the dent puller. Sounds like
that must have worked for you. I would like to try that since I'm short on space and time, otherwise I'd split the cases just to be sure all is clean And good. Thanks!
#12 WHdbJD ONLINE
WHdbJD
  • 649 Thanks
  • 488 posts
Posted August 14, 2012 - 09:24 PM
OK, I got a couple leaking axle seals, and a couple questions....
1) Any one have a part number or source for the seals and
2) does the right side of my 601 Suburban use the same seal as my 597 amd 100 walk behinds?
#13 VSTROM803 OFFLINE
VSTROM803
  • 371 Thanks
  • 338 posts
Posted August 15, 2012 - 03:30 AM
This info is from the DBATTACHMENT site:
CR11223 - axle - 2 -/- CR7513 - Clutch - 1
Also, you can clean off the seals that are in it and you should see a number that can be crossed referenced. They're probably National brand seals. Your new ones probably won't look like the originals.
  • Alc and WHdbJD have said thanks
#14 WHdbJD ONLINE
WHdbJD
  • 649 Thanks
  • 488 posts
Posted August 16, 2012 - 01:52 AM
Thanks for the seal numbers , VSTROM803.
I'll put them in the file , seal replacement looks like a good project for thei winter!
