What Other Tractors Use Peerless 2301-a
10 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 11, 2012 - 12:51 AM
Alright, I think I know the model Peerless found in the 4 speed Springfields/Toros to be a model 2301-A. So now the hunt is on to determine if ANY other brand used that specific model of Peerless. So what I need from you guys, is simple, review your manual, crawl under your 4 speed Peerless driven tractors, find those model numbers. I do not plan to cabbage the transaxles out of your tractors, just out of parts tractors. Any help is appreciated. I would need to know the make and model of each tractor investigated, and the results of your findings. This thread could become useful to other guys having similar issues with locating replacement transaxles. I will start with one of mine and that will give everyone a sample format.
GE Elec-Trak E-20 has Peerless 2318.
Good luck guys, and enjoy your research. Thank you.
#2 KennyP ONLINE
  • 40,007 Thanks
  • 46,718 posts
Posted August 11, 2012 - 06:19 AM
The Ford/Jacobsen 10-12HP gear drives used the 2306A Peerless. Not sure of the difference from a 2301A.
  • wvbuzzmaster said thank you
#3 MH81 OFFLINE
Posted August 11, 2012 - 07:33 AM
Anyone with a MF7 or 8G who can verify what they had?
#4 HowardsMF155 OFFLINE
  • 2,885 Thanks
  • 2,996 posts
Posted August 11, 2012 - 07:38 AM
I can verify it is a 3 speed and not ground engagement rated. I'm pretty sure that makes it not a 23xx series. I do need to look at the MF 10-12 transmission, as that is a peerless four speed.
Ok, I went out and checked on my MF-10:
MF-10 has a Peerless 2309
Edited by HowardsMF155, August 11, 2012 - 07:47 AM.
#5 MH81 OFFLINE
Posted August 11, 2012 - 08:12 AM
The tranny Casey is asking about ( I believe ) is from an 8 HP Springfield. It has 3 forward speeds and one reverse. The 10 has 4 forward and one reverse.
#6 HowardsMF155 OFFLINE
  • 2,885 Thanks
  • 2,996 posts
Posted August 11, 2012 - 09:40 AM
Ok, I will check my mf8, but I was going by what he wrote in his initial post : 4 speed. I'll be back (add your own Terminator effects here)
  • MH81 and wvbuzzmaster have said thanks
  • 14,862 Thanks
  • 15,511 posts
Posted August 11, 2012 - 11:54 AM
Casey, I can tell you that Wheel Horse did not use that model of Peerless Trans. in any of their tractors.
#8 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 11, 2012 - 12:08 PM
The 3 speed Peerless is a 1700, I want to find more 2301-a Peerless since those are 4 speed and more stout. I know WH never used Peerless, so mostly looking at Massey, Deere, and others with Peerless transaxles.
#9 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted August 11, 2012 - 12:44 PM
Wheel Horse used several different models of Peerless trans., but just not the 2301..
#10 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 19, 2012 - 02:35 AM
Learning more about 2300 transaxles every day. I have found out a source for the left axle housing on the Springfield version of a 2300. Elec Trac 2318 has the proper housing on both sides, so no match on the Springfield right housing yet. If I can find a version of the 2300 that has the brake on the right hand side and the drive pulley on the left I will be so close to making my own 2301-A's out of hodge podges lol.
#11 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,291 posts
Posted August 19, 2012 - 03:39 AM
As seen on the forum start site: What Other Tractors Use Pee... :laughingteeth: :bigrofl: :bigrofl:
Edited by jd.rasentrac, August 19, 2012 - 03:39 AM.
