210 John Deere Lawn Tractor Drive Belt Ajusting
3 replies to this topic
#1 JD210 OFFLINE
JD210
  • 1 posts
Posted August 08, 2012 - 12:48 PM
i have a 210 john deere lawn tractor is there any way to tightening up the belt or doesn't it need to be replaced it come off the pulleys when u put the small throttle leaver in high position.
Edited by JD210, August 08, 2012 - 02:16 PM.
#2 lyall ONLINE
lyall
  • 231 Thanks
  • 423 posts
Posted August 09, 2012 - 10:01 PM
Hi JD210
which belt is coming off - the one to the mower deck or the one from the motor to the variator or the one to the transaxle
for the one to the mower deck - first check the pulleys to see if one or both are bad
to tighten the mower belt turn the handle part number 14 in the picture
for the variator - you can try tighten the eye bolt number 3
if you need to replace the two drive belts go to a local John Deere and get them, don't buy belts from hardware store or places like that. Deere belt have a different angle on the belts and they will last the other don't
you should check the variator to see if the center part slides freely.
if it does not - use only graphite power - do not use oil causes the belts to slip
good luck and let us know how it goes
come back if you need any more help
there are a lot of great people here that can help
#3 mjodrey OFFLINE
  • 2,195 Thanks
  • 13,476 posts
Posted August 18, 2012 - 06:03 AM
jd210,welcome to the forum.Glad to have you with us.
#4 KennyP OFFLINE
  • 5,870 Thanks
  • 18,738 posts
Posted August 18, 2012 - 06:40 AM
Welcome to the forum. It looks like lyall has you fixed up. Good luck!
