149 Hydraulic Lift Capacity
12 replies to this topic
#1 virginiacubfan OFFLINE
virginiacubfan
  • 51 Thanks
  • 43 posts
Posted August 05, 2012 - 02:31 PM
Hi everyone, I am new to the site and love it already! I recently purchased my first hydro cub cadet and I have a few ideas in mind for some homemade implements and I was wondering if anyone knew the lift capacity of the hydraulic system. I look forward to the input.
#2 KennyP ONLINE
  • 40,142 Thanks
  • 46,773 posts
Posted August 05, 2012 - 02:33 PM
Welcome to GTTalk! I haven't a clue to the lift capacity, just wanted to say Hi!
  • virginiacubfan said thank you
#3 KC9KAS ONLINE
KC9KAS
  • 5,444 Thanks
  • 4,712 posts
Posted August 05, 2012 - 04:20 PM
Welcome to the GTT forum.
I don't have the answer to you question either, but I'm sure someone will come along soon that will have the answer. A lot of knowledge is sitting in wait here!
#4 JDBrian OFFLINE
  • 9,645 Thanks
  • 14,158 posts
Posted August 05, 2012 - 04:48 PM
Welcome to GTTalk. Glad you like it here. CC may not have published a weight capacity for the lift. If you have a look at the attachments that CC and third party companies made for use with the lift that will give you a good idea of the capacity. The lift capacity is usually limited by the designers to a safe amount for the size of the tractor.
#5 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted August 05, 2012 - 06:15 PM
It will probably lift way more than the tractor can safely lift. But I would say 300 lbs is about right for most attachments.
#6 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted August 05, 2012 - 08:51 PM
:welcometogttalk: No clue from me, wouldn't mind seeing pics though. :camera: Looking forward to that answer too..Thanks for signing up.
#7 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted August 05, 2012 - 10:23 PM
Start low and work up to where is is sill stable. Good Luck
#8 Cvans ONLINE
  • 7,087 Thanks
  • 6,294 posts
Posted August 06, 2012 - 10:47 AM
It's been my experience that they will lift enough so that the front end gets too light for good steering. I used the hydraulic system on my CC dumpster and that will lift over 400 lbs. before the bypass opens. Anything over that would be seriously taxing a tractor this size.
#9 virginiacubfan OFFLINE
virginiacubfan
  • 51 Thanks
  • 43 posts
Posted August 06, 2012 - 07:53 PM
Thanks for all the good from everyone! My main goal is to fabricate a 3point hitch on the back so i can use all of my Sears Suburban Brinly implements on the 149. It will probably be more of a winter project since it is still too hot in a non a/c workshop...this virginia humidity can be miserable!
#10 mjodrey OFFLINE
Posted August 09, 2012 - 04:38 AM
Welcome to the forum.Glad to have you with us.
#11 Cvans ONLINE
  • 7,087 Thanks
  • 6,294 posts
Posted August 09, 2012 - 08:56 AM
It has been my experience that the hydro will lift more than you can with the manual lift. I put the 149 hydro and lift on my 129 and I love it. Works fast and has a bunch of power.
#12 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted August 10, 2012 - 11:10 PM
:welcometogttalk:
#13 EricFromPa ONLINE
EricFromPa
  • 3,985 Thanks
  • 3,253 posts
Posted August 14, 2012 - 04:36 PM
My 149 has 225lbs of weight on my extended Sleave hitch pin and the plow up front on and it had no problem lifting both at the same time.I'm in the process of gathering materials for a 3 point build up that will be adapted to my exsisting Sleave hitch.
But 1st I have to change a leaking Cork pump seal and driveshaft flex disk.
