Jacobsen Gt10 Help
22 replies to this topic
#1 kenbhall OFFLINE
kenbhall
  • 17 Thanks
  • 55 posts
Posted August 04, 2012 - 07:22 AM
I have a GT10 that I acquired a while back it has been waiting patiently for me to start working on it. I realize that some parts that I don't have will be hard to find , so I am finally going to try to start the project. There are a few problems I need to sort out first.
Problem 1 can someone tell me what model Kohler this is ? I can't find any numbers on the engine!
I do know it is a GT 10 I have the I'd plate from the tractor
Problem 2 I don't know the underwood layout ( gas tank, coil mounting and such)
If anyone has one of these could you please post some pix of the engine and locations of the coil ?
I do not have the hood or grill I do have very strong sheet metal for the rear
Here are some pictures of what I am starting with. ImageUploadedByTapatalk1344082757.762811.jpg ImageUploadedByTapatalk1344082875.926036.jpg
#2 KennyP ONLINE
  • 37,408 Thanks
  • 45,457 posts
Posted August 04, 2012 - 08:01 AM
Welcome! Kind of hard to tell much with the body parts missing. Have you got a pic of the fenders? Maybe a side view?
Were there any #'s like 09?????? or 5???? on the ID tag?
#3 kenbhall OFFLINE
kenbhall
  • 17 Thanks
  • 55 posts
Posted August 04, 2012 - 08:57 AM
Here is a pic of the fenders and yes I do have the I'd plate it was in bad shape so it's not on the machine anymore , I just have to find where the wife put it. ImageUploadedByTapatalk1344088468.759466.jpg ImageUploadedByTapatalk1344088621.164869.jpg
#4 KennyP ONLINE
  • 37,408 Thanks
  • 45,457 posts
Posted August 04, 2012 - 09:28 AM
I think this would be the same as the LGT 100 Ford since it has the tube frame. Here is the repair manual link:
http://gardentractor...-repair-manual/
There is also an owners and parts manual for these in the manuals section. See if that doesn't look like yours.
  • kenbhall said thank you
#5 kenbhall OFFLINE
kenbhall
  • 17 Thanks
  • 55 posts
Posted August 04, 2012 - 09:56 AM
thank you for the link Hopefully that will do the trick Id really like to get this one going again. It was on the sid of the road with a fre sign on it and I just couldnt drive by.
  • JDBrian said thank you
#6 JDBrian OFFLINE
  • 9,601 Thanks
Posted August 04, 2012 - 10:27 AM
That has potential to be very nice and the price can't be beat. If it's a 10hp kohler then it should be a K241. The spec no. would tell you how the engine is configured.
#7 kenbhall OFFLINE
kenbhall
  • 17 Thanks
  • 55 posts
Posted August 04, 2012 - 11:27 AM
Wow I see my wife's computer has a problem with the letter E , I will pull the engine out of my storage tent a little later and search for bombers but I really don't remember seeing any there. And yes I saw some fun and potential when I picked it up.my first thought was tube frame garden tractor = puller !
#8 kenbhall OFFLINE
kenbhall
  • 17 Thanks
  • 55 posts
Posted August 04, 2012 - 11:29 AM
Wow and my iPhone is paranoid it said bombers when I wanted numbers ! Or maybe my thumb is just too big for typing .
#9 KennyP ONLINE
  • 37,408 Thanks
  • 45,457 posts
Posted August 04, 2012 - 11:48 AM
If that manual is the correct one, then the engine is a K241AQS, spec-4674O-D. Best of luck with it.
#10 kenbhall OFFLINE
kenbhall
  • 17 Thanks
  • 55 posts
Posted August 04, 2012 - 01:06 PM
I'm going to have to get out my Kohler manual for that engine thanks again Kenny
#11 KennyP ONLINE
  • 37,408 Thanks
  • 45,457 posts
Posted August 04, 2012 - 01:10 PM
No problem, Ken! You folks keep bringing in these 'oddball to me' Jakes and Fords and I am learning. Be sure to holler if something else is needed.
#12 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted August 05, 2012 - 07:46 AM
That is one of the early 70's Jacobsen s as the oil pan is welded into the frame and it has a standard shift trans, so that really makes it a 10hp :)
#13 KennyP ONLINE
  • 37,408 Thanks
  • 45,457 posts
Posted August 05, 2012 - 08:04 AM
Kieth, take a look at the frame again. There is a big hole right where the engine mounts. No oil pan there.
#14 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted August 05, 2012 - 09:41 AM
Still an old style but has been modified for something else.. But still an early seventys steering linkage gives it away and so does the dash/ steering column :)
#15 kenbhall OFFLINE
kenbhall
  • 17 Thanks
  • 55 posts
Posted August 05, 2012 - 10:33 AM
I forgot to ask the wife where to find my I'd plate I'll look later I know the numbers were still there. I found a look up site that told the year from the numbers once but my computer crashed . Anyone happen to know of the site ? If I remember correctly I believe it was a 74 .
