Back To Eden Gardening
8 replies to this topic
#1 lyall OFFLINE
lyall
  • 1,807 Thanks
  • 1,428 posts
Posted August 01, 2012 - 10:36 PM
Check out this site. using wood mulch. a lot of info to read and listen to. it is interesting
http://backtoedenfil...bout/index.html
  • LilysDad said thank you
#2 speedyg OFFLINE
speedyg
  • 71 Thanks
  • 434 posts
Posted August 02, 2012 - 01:45 AM
lyall, Thanks for passing down the vidio, stayed up way late watching it, just had to finish it to the end though. Good info for the garden and the soul.
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,544 Thanks
  • 4,063 posts
Posted August 02, 2012 - 06:12 AM
At germany we call it Bio-Anbau or Bio-Landwirtschaft. The products are a little more expensive and look natural (not even as in the video). A slogan here is: we have this earth just leased from our children.
#4 twostacks OFFLINE
twostacks
  • 450 Thanks
  • 427 posts
Posted August 02, 2012 - 09:49 AM
It is very interesting. I watched about 15 minutes of it and I want to finish it. Thanks for posting.
#5 speedyg OFFLINE
speedyg
  • 71 Thanks
  • 434 posts
Posted August 03, 2012 - 02:09 AM
jd.rasentrac, What do you mean by the products are more expensive and look natural ( not like in the video ) could you explain a little more please. thankyou !
  • jd.rasentrac said thank you
#6 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,544 Thanks
  • 4,063 posts
Posted August 03, 2012 - 04:13 AM
Many farmers at germany produce bio-food. As seen in the video, they don´t plow the field and use organic manure. Chemical fertilizier is shut down to the absolute minimum. Using spray chemicals (pesticide, herbicide) and mutated seeds is not allowed.
The field will be grubed (from to grub - we call it grubbern) and then sowing starts.
Harvest yield in alternative farming is lower than in orthodox, that makes the goods more expensive.
The skin of vegetable and fruit can be blurry. So it doesn´t look so fine as you see in fruit advertising.
But farming this way saves the environment and the agricultural products taste as well as orthodox produced - some people say, that natural products have a better taste.
And there´s no difference between gardening and farming here in germany. All this is made for protecting drinking water, the biggest treasure on earth.
I hope, I found an answer to your question - tried to explain as well as I can :blush2:
Edited by jd.rasentrac, August 13, 2012 - 01:11 PM.
#7 speedyg OFFLINE
speedyg
  • 71 Thanks
  • 434 posts
Posted August 05, 2012 - 11:06 PM
The field will be gruped and then sowing starts.
You did well, thanks for taking the time to address my guestions.
#8 LilysDad OFFLINE
LilysDad
    Crazy about GTTalk
  • 10,509 Thanks
  • 8,131 posts
Posted August 13, 2012 - 12:57 PM
What is "gruped", please???
#9 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,544 Thanks
  • 4,063 posts
Posted August 13, 2012 - 01:08 PM
Sorry, special words are hard to translate sometimes - the right way. We call it "grubbern", and I found the english word "grub". So grubed will be better?
And you have to use this implement for example
Edited by jd.rasentrac, August 13, 2012 - 01:15 PM.
  • lyall and KennyP have said thanks
