Tecumseh Piston Markings?
9 replies to this topic
#1 HowardsMF155 OFFLINE
  • 2,750 Thanks
  • 2,936 posts
Posted July 31, 2012 - 06:04 PM
I'm thinking about rebuilding, or at least re ringing, a Tecumseh HH120 engine on my Massey. For those who followed it, this is the one with valve clearance issues and the timing problem. Now that it has been run hard a little with fresh engine oil, it is starting to smoke and use some oil. How do I tell what the current piston size is? I didn't see any markings. Should I assume that an unmarked piston is standard? If they are marked, where should I be looking, center, flywheel side, crankshaft side?
Thanks
#2 JDBrian OFFLINE
  • 9,595 Thanks
Posted July 31, 2012 - 06:52 PM
Not sure on a Tec but it's usually on the top of a Kohler piston. The Tec's I've had apart do not have any markings on the piston but they have all been the original part.
  • HowardsMF155 said thank you
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted July 31, 2012 - 06:55 PM
I have a HH120 with a .30 over piston and it's marked on top.
  • MH81 and HowardsMF155 have said thanks
#4 HowardsMF155 OFFLINE
  • 2,750 Thanks
  • 2,936 posts
Posted July 31, 2012 - 07:03 PM
Do you remember where the marking was? Was it centered, or off to the side, or just can't quite remember?
#5 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 31, 2012 - 07:11 PM
It was off to the side, I don't remember if it was marked as .030 or just 30. It was easy to see.
#6 olcowhand ONLINE
  • 37,720 Thanks
  • 30,340 posts
Posted July 31, 2012 - 08:27 PM
All I've ever seen were marked off from center on top of piston. The top of piston is always where the oversize markings are. Some will be marked "STD" for standard, but if no markings at all, it's standard size also.
#7 DH1 OFFLINE
DH1
    Electric Tractors
  • 4,935 Thanks
  • 5,435 posts
Posted July 31, 2012 - 08:32 PM
Here's one that I found
  • Bruce Dorsi and HowardsMF155 have said thanks
#8 DH1 OFFLINE
DH1
    Electric Tractors
  • 4,935 Thanks
  • 5,435 posts
Posted July 31, 2012 - 09:20 PM
Here's another one, standard size of the 10hp HH100.
  • Bruce Dorsi said thank you
#9 HowardsMF155 OFFLINE
  • 2,750 Thanks
  • 2,936 posts
Posted July 31, 2012 - 09:25 PM
Ok, so it looks like if it is marked it will be marked on the crankshaft side. And if no marks are found, then it is standard size. Thanks guys!
#10 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted August 01, 2012 - 04:24 AM
The only time "crankshaft side" would make a difference is if the wrist pin is offset in the piston, in that case the piston would have a notch on one side pointing the proper direction.
Edited by Amigatec, August 01, 2012 - 04:25 AM.
