Brinly Back Blade, Making It Work.
8 replies to this topic
#1 MH81 OFFLINE
Posted July 16, 2010 - 08:18 PM
I had to do some work on my parking area beside the house. The rain keeps washing in sandy soil and then it gets muddy. I am getting a load or 2 of good gravel this fall, but had to remove some of what was there. I put in an ad for sleeve hitch attachments & a guy with a back blade called. He sold it to me for $15, I gave him a twenty. He was a really nice guy. After I got home, I decided it needed to be a box scraper. here's some pics of me usin' what was laying around (end panels are 1/4" plate from an old Satellite Dish Mount and the scarifiers are what was left of an old MH pony cultivator)
Might not win a beauty pageant, but sure works well (with the cement block).
Edited by MH81, June 22, 2013 - 07:50 PM.
  • backwoods said thank you
#2 olcowhand ONLINE
  • 41,216 Thanks
  • 31,437 posts
Posted July 16, 2010 - 08:31 PM
Pretty tools do no more work than Plain-Janes anyway. And much less to worry about....no paint to scrape up. You got a great deal on that! BTW......Welcome to GTT!
#3 MH81 OFFLINE
Posted July 16, 2010 - 08:41 PM
Thanks, My wife even thought I got a good deal. LOL
#4 MH81 OFFLINE
Posted June 22, 2013 - 12:17 PM
Three years later and I'm still using it.
Decided the inability to use the angle without removing the scarifier bracket was finally an issue.
Ryan and I removed the teeth and cut some pieces of 1/4" high carbon. A little more figuring on how far down the teeth should be and we can finish it up with 6 or so holes.
image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
  • olcowhand and backwoods have said thanks
#5 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted June 22, 2013 - 08:36 PM
The one I have looks like this, side plates are up 3/4" above the bottom edge of the blade and the teeth are down about 1" below the side plates.
  • olcowhand and MH81 have said thanks
#6 MH81 OFFLINE
Posted June 22, 2013 - 08:55 PM
Dotted the i's and welded the t's... Got to use it today.
Works better with weight, but out on the end of the sears adapter +80# is a little much. It worked fine with the Brinly on the GT6000, but I wanted to play with the ST16
The bank gravel parking area had gotten rutted and a bit of a mess. The back blade with new "dentures" worked great. And it's nice to spin the blade around.
Big thanks to my big (and little) helpers
  • olcowhand, DH1 and KennyP have said thanks
#7 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted June 23, 2013 - 10:22 AM
wow looks like its working great for you guys now
#8 olcowhand ONLINE
  • 41,216 Thanks
  • 31,437 posts
Posted June 23, 2013 - 10:34 AM
I have one of these Brinly blades, but never used it.  Thought of using it, just never got to it, as I have a heavier unit I use.  But adding scarifier teeth to the Brinly would be easier than my heavy unit.  I was just thinking, if the scarifier bracket were pinned to hinge, then a metal piece on the lower leading edge of the bracket came against the side wall plates, that would lock it automatically to dig.  Then one could add a blade edge on the rear of the blade, and one could back push without turning things around, and the scarifier teeth would simply hinge forward during the back push.
  A locking spot could also be added to where you could pin the scarifiers up out of the way when you don't want/need them.
#9 KennyP OFFLINE
  • 38,418 Thanks
  • 45,945 posts
Posted June 23, 2013 - 11:02 AM
Looks good, Alan! You guys did a great job with that. Just have to watch turning the tractor around with that back there.
