Have A Few Questions On A Mackissic Shredder (for Bolens)
46 replies to this topic
#16 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted August 10, 2015 - 10:53 AM
Brian,I was thinking they used the same u-joint as the blowers,maybe mount the frame up and check
#17 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted August 10, 2015 - 11:29 AM
I originally thought that to until I bolted it up and it was about 3'' too short, if you look at oldbuzzards pics the universal coupling has a much longer housing than the tubeframe's 1715008 joint.
I wonder if the special u-joint had a mackissic or Bolens part number.....
#18 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted August 10, 2015 - 11:34 AM
I've got a bunch of pics of when I rebuilt my two chippers. Also have lots of info on them. Feel free to PM me and I can email you stuff if you want.
  • Bolens 1000 and stiemmy have said thanks
#19 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted August 10, 2015 - 11:57 AM
That U-joint was supplied by MacKissic with the shredder attachment.
http://gardentractor...y-mac-shredder/
Edited by Bruce Dorsi, August 10, 2015 - 12:03 PM.
  • Bolens 1000, Alc and stiemmy have said thanks
#20 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted August 10, 2015 - 12:42 PM
Brian, there were 2 different brackets supplied by mackissic, one was to fit the tubeframes with the mower deck linkage installed and there was also an optional bracket to fit the tractors without.
I can give you the dimensions of mine which is for tractors that have the mower linkage installed.
Edited by chubien, August 10, 2015 - 02:19 PM.
  • Bolens 1000, Bruce Dorsi and stiemmy have said thanks
#21 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted August 10, 2015 - 12:51 PM
Chubien that would be great!
I'm likely to leave the deck linkage on so would like to get the specs on that bracket
Thanks!
#22 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted August 10, 2015 - 02:21 PM
I'll post something up tomorrow when I'm back at home.
#23 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted August 10, 2015 - 02:57 PM
Brian,Bruce,Thanks for the info
#24 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted August 10, 2015 - 05:54 PM
Brian, I took some measurements and also a few pics. The bracket is still on the tractor so it could be better, let me know if you have any questions.
You'll notice I have the different bracket to what is pictured above.
The bracket is constructed of the same gauge stock as the shredder frame, the dimensions are all outside dimensions
  • Bolens 1000 and Bruce Dorsi have said thanks
#25 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted August 10, 2015 - 05:55 PM
ImageUploadedByTapatalk1439247308.401242.jpg ImageUploadedByTapatalk1439247331.918470.jpg ImageUploadedByTapatalk1439247341.039355.jpg
  • Bolens 1000, MH81 and stiemmy have said thanks
#26 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted August 10, 2015 - 06:06 PM
Thank you that is perfect!!
#27 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted August 10, 2015 - 09:13 PM
I was wondering about the belt tensioner oldbuzzard was mentioning, mine does not have a tensioner and I could not tell how his is setup from the pics he posted since it must be under the cover.
I always assumed that the belt tension was done by the way the mulcher sits spring loaded on the frame.
Mine worked well without a tensioner but it did smoke the belt for a few seconds after I overloaded it.
  • MH81 and stiemmy have said thanks
#28 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted August 11, 2015 - 04:10 AM
That is indeed how it works.
If you look at the next to last page in the manual that Bruce linked to, you can see two springs listed as item #13 on the parts diagram.
  • stiemmy and Chubien have said thanks
#29 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted October 06, 2015 - 06:23 PM
Can someone who has one of these chippers provide the length of the springs that go in the hopper holes for belt tension?
There were two different springs on mine and want to know which is original
#30 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted October 07, 2015 - 05:16 AM
I can't give you a definitive answer for another week but off the top of my head I remember them being almost flush with the tube edge. Maybe 1/4 or 1/2 inch below.
Btw, not sure if your frame is in good shape but of all things to find there is a complete frame in as new condition for sale on eBay, no chipper, just the frame.
Same guy also has a generator for tube frames and other stuff.
Edited by chubien, October 07, 2015 - 05:21 AM.
