Have A Few Questions On A Mackissic Shredder (for Bolens)
46 replies to this topic
#1 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 29, 2012 - 07:24 PM
I have a chance to buy this shredder. It looks pretty rough and may have parts missing???
Here's the pics I was sent.
If someone with one of these could take some pictures so I can see what parts are possibly missing that would be great.
  • CharlesDes said thank you
#2 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted July 29, 2012 - 07:37 PM
Here are some pics/info/links.
I don't know much about them, as I just got mine, and have'nt had time
to look into it yet.
http://gardentractor...e__hl__ chipper
  • Bolens 1000 said thank you
#3 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 29, 2012 - 07:45 PM
Thanks
Its not that far from me so Mabye I'll print out a few pictures from the ones in that thread and bring it with me to compare.
#4 grand OFFLINE
grand
  • 2309 Thanks
  • 2074 posts
Posted July 29, 2012 - 08:01 PM
Brian I went to the garage and took several pics of the shredder I bought. It is the one that you found on Craigslist that was close to us. That same fellow also had the Brinly dump cart. Will as always is right on the ball and posted before I got my pictures taken and posted. His shredder is the same brand but it looks like the mountings are different. Mine doesn't have the pulleys but a driveshaft. Hope this helps.Shredder 001.JPG Shredder 002.JPG Shredder 003.JPG Shredder 004.JPG Shredder 005.JPG
  • Bolens 1000 and Bruce Dorsi have said thanks
#5 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted July 29, 2012 - 08:23 PM
i found a video of one in action ... i see that you commented on it
  • Bruce Dorsi said thank you
#6 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted July 29, 2012 - 08:27 PM
Get it if the price is right....
#7 MailmAn OFFLINE
MailmAn
  • 389 Thanks
  • 776 posts
Posted July 29, 2012 - 09:39 PM
It looks like it is missing some side and/or bottom panels to enclose the shredder parts... or is it just the camera angles the photos are taken at? Grand's pics of his make it look like there are more side/bottom sheet metal panels. I know there has to be some kind of discharge chute for the shredder, but that one looks like the whole front side is open, which is a safety hazard as well as it just can't shred anything if it's not enclosed enough! That's just my thought though looking at it...
EDIT - I'd also add, it does look from that excellent video, like the one you are looking at Dr. Bolens is missing the bottom sheet metal and the discharge "screen" it has in the video to be sure it is holding the branches and brush in the shredder part until the debris is small enough to exit the shredder area. Without this, I'd think the mulch it produces would be much too "thick" or just incompletely shredded.
I DO like this model better than a different shredder I think Old Buzzard posted about as it mounts on the BACK of the tractor rather than the front. For some reason to me at least, it seems more intuitive that it should mount on the back and not the front of the tractor.
Edited by MailmAn, July 29, 2012 - 09:50 PM.
#8 Littledeere OFFLINE
Littledeere
  • 1693 Thanks
  • 1511 posts
Posted July 29, 2012 - 09:50 PM
The good thing is there are some parts to be had they are still in business
and parts for some of the self powered units are the same I may even have some of the parts you need
I have one I'm going to part out
#9 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 29, 2012 - 09:54 PM
Grab it!!!
There doesn't appear that there is anything missing that you can't get straight from Mackissic.
http://www.mackissic...sories.html#HSC
The only thing that you may not be able to get from Mackisssic is the part that puts tension on the belt. It would be easy to fab though because it's just a piece of flat stock, two pieces of tube, and two springs.
  • fordtrac said thank you
#10 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 30, 2012 - 07:10 AM
ok, So can you guys tell if all the hammers/ internal parts are there?
Can you snap a few more pics of the chute,bottom and inside Grand?
If its going to cost more to buy parts than what I can find another complete one for then I will just have to pass on it.
#11 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 30, 2012 - 08:29 AM
Looks like all of the hammers are present. There should be 24 of them.
It's missing the screen (available from Mackissic), the swinging door (easily fabbed), the 3 rods that attach then (also easily fabbed), the front belt guard (again easily fabbed), and maybe the belt tensing support.
The screen would be the only expensive part. It seems that the 12P uses the same part numbers for those. They are $89.00 each. The standard one is the 1" one (PN 500-04).
Here's some pics of mine showing the areas in question.
  • Bolens 1000, Bruce Dorsi and MailmAn have said thanks
#12 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 30, 2012 - 08:53 AM
Thanks for all the help guys
I will keep you updated if I end up getting it
#13 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted July 30, 2012 - 09:09 AM
Where does the pointed pin on the back end of the shredder frame contact the tractor?
Is there a bracket which gets mounted to the tractor to receive the pin?
#14 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted July 30, 2012 - 09:22 AM
Yep:
#15 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 10, 2015 - 07:59 AM
Well 3 years later on this thread and I am now the owner of the same shredder in the first post :D
Bought it off another member on here last week
Can one of you guys supply some dimensions for the bracket that supports the shredder to the frame of the tractor (Post 14)
Also looks like I'm going to have to modify the universal joint as the piece that attaches to the spline front of the tractor pto is missing and looks  alot longer than the one used for the Bolens decks, blowers ect. I'm thinking on just ordering some longer square stock and welding a new longer shaft on the chippers universal coupling.
