2300 Tranny
4 replies to this topic
#1 speedyg OFFLINE
speedyg
  • 71 Thanks
  • 434 posts
Posted July 29, 2012 - 05:50 PM
Is the 2300 series tranny housing cast iron or aluminum?
#2 olcowhand ONLINE
  • 41,037 Thanks
  • 31,384 posts
Posted July 29, 2012 - 06:33 PM
The 2320 as used in Massey & others is aluminum tranny housing, with bolt on cast iron axle tubes.
  • speedyg said thank you
#3 speedyg OFFLINE
speedyg
  • 71 Thanks
  • 434 posts
Posted July 29, 2012 - 08:01 PM
I have been looking into a JD 110 I beleive it has a four speed peerless tranny in it. And was wandering what the housing or case was made of. And if all of the 100 series had the same tranny?
#4 Trav1s ONLINE
Trav1s
  • 3,290 Thanks
  • 4,351 posts
Posted July 29, 2012 - 08:03 PM
All JD 110/112 and 200 series use the same peerless transaxle. There is some difference in the brake assemblies but they interchange with each other.
#5 olcowhand ONLINE
  • 41,037 Thanks
  • 31,384 posts
Posted July 29, 2012 - 08:08 PM
I brain farted. Once you said JD110, I realized it. The 2520 is the one I thought of in the larger Massey's, but I have a 2316A transaxle out of a JD110 (year unknown), and it is all cast steel, or iron. These same series transaxles are in some smaller Massey, and also used in the V series Bush Hog tractors....all steel/cast.
