* * * * - 3 votes
Putting Drive belts on a tubeframe Garden tractor...
14 replies to this topic
#1 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted July 16, 2010 - 02:32 PM
Figured I'd post this as a sticky for others who need to know how to do this ...
1) First you will have to loosen the large nut on the dive shaft. It may be helpful to hold the shaft in the back with a pipe wrench as you loosen the nut.
Once you get the large nut off take out the two smaller ones.
Now take off the two bolts on each side and the plate should slide out. It may take some force if the bearing is froze on the shaft.
2) next, To replace the drive belts you MAY have to remove the 4 engine mount bolts and spacers to be able to slip the belts on and off.
 Almost all times you can get the belts on/off without removing the engine mount spacers, but have heard others had to do this from time to time.
[B]Once you do this you will be able to slide the old belts off and put the new ones on. For the old 3 speed models you can just lock the idler pulley away from the belts. Newer 6 speed models require you to hold back the idler while doing this
:bounce:
  • Bill56, cranecreekdave, Aussiedog and 14 others have said thanks
#2 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted July 16, 2010 - 10:57 PM
Great information Brian. Especially helpful to have the photos along with the explanation.
  • chieffan said thank you
#3 mvp1114 OFFLINE
mvp1114
  • 1 Thanks
  • 3 posts
Posted July 25, 2011 - 12:45 AM
Woof. Just what I was looking for! The belts I "inherited" are pretty ratty.
Mike
#4 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted February 19, 2012 - 03:14 PM
WOW THATS BE A BIGGER JOB THAN I THOUGHT THANKS FOR THE HELP AT LEAST I HAVE SOME IDEA OF HOW TO DO IT. 1971 1054 HUSKY
GOODNEWS
Edited by goodnews, May 29, 2012 - 05:03 PM.
  • Huskyfan and chieffan have said thanks
#5 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted February 19, 2012 - 03:32 PM
WOW THATS BE A BIGGER JOB THAN I THOUGHT THANKS FOR THE HELP AT LEAST I HAVE SOME IDEA OF HOW TO DO IT. 1971 1050 HUSKY
GOODNEWS
Once you do it a few times it becomes quite simple
Usually you can change the belts out without having to loosen the engine mounting bolts.
Drive belts : 1736259
PTO Belts : 1716570
Starter Belt : 1714690
The Bolens 1050 was made from 1966-1969
  • goodnews, BolensNewb88, Huskyfan and 2 others have said thanks
#6 wheelhorse2 OFFLINE
wheelhorse2
  • 4 Thanks
  • 22 posts
Posted March 16, 2012 - 10:38 PM
Thanks, this will help with my 850
  • MyBolens1053 and chieffan have said thanks
#7 BolensNewb88 OFFLINE
BolensNewb88
  • 20 Thanks
  • 34 posts
Posted May 03, 2012 - 11:45 PM
If you check on ebay and type in the Bolens belt part numbers for the belts you will find some good deals on belts
PTO Belts : 1716570
PTO Belts : 1716570
will those fit my 1000 ?
#8 BolensNewb88 OFFLINE
BolensNewb88
  • 20 Thanks
  • 34 posts
Posted May 03, 2012 - 11:47 PM
PTO Belts : 1716570
i think they just may lol
#9 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted May 04, 2012 - 06:23 AM
PTO Belts : 1716570
Yes those will fit
If your buying on ebay be sure to get Kevlar belts (Not the rubber FHP belts that are on there for $7-$12 as they are not power rated)
  • BolensNewb88, Huskyfan, chieffan and 1 other said thanks
#10 BolensNewb88 OFFLINE
BolensNewb88
  • 20 Thanks
  • 34 posts
Posted May 04, 2012 - 09:14 AM
Yes those will fit
ok thanks :)
#11 locoman OFFLINE
locoman
  • 7 Thanks
  • 12 posts
Posted December 29, 2012 - 12:59 PM
very usefull information. I need to change all my belts on my 4 work tractors. I bet by the last 1 i will be getting good at it. thanks again for the great information
#12 MyBolens1053 OFFLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted November 17, 2013 - 12:46 AM
Definitely a 'good to know' post. Thanks.
#13 68guns OFFLINE
68guns
  • 123 Thanks
  • 80 posts
Posted October 28, 2014 - 12:35 PM
If you have a 3 speed model (G10) etc. The job takes about I minute. Nothing to remove. Depress clutch..replace old belt with new..Voila'!
  • chieffan, Bolens800uk and Dubmatix have said thanks
#14 rumbleseat OFFLINE
rumbleseat
  • 125 Thanks
  • 80 posts
Posted March 11, 2015 - 10:46 PM
Changed mine today using this post. Thanks!
#15 wurzel OFFLINE
wurzel
  • 120 Thanks
  • 104 posts
Posted February 07, 2016 - 05:12 AM
hi just used these part numbers in UK for my H16/1656-03
H16 Drive belt   2 off  4L300 Kevlar
H16 pto belts  2 off  4L430 kevlar
cheers nick
  • Bolens800uk said thank you
