317 Fuel Pump Replacement
8 replies to this topic
#1 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted July 26, 2012 - 03:31 PM
On my 317, the Fuel Pump went out.Posted Image
Took Battery and tray out. Cleaned and painted tray, then painted with Rustoleum Rubber Spray Sealer.
Located and mounted the pump. Had a little concern about Fuel Filter location. Wanted it mounted before the pump, but didn't want to locate it back on the frame, just after the shutoff valve. Too hard to get to! So I left it under the battery and had a piece of left over Tygon Tubing from a different project, fastened that to filter and then was able to flex it to hook to pump without kinking the line!!
Wired up to the Aux plug on the Light switch with a 5 amp Fuse.
Remounted the tray, hooked up the Battery, put side covers on. Turned the key and let the pump run maybe 10 seconds, and she RUNS!!! Originally I used the Tygon hose from Filter to pump, not from pump up to Carb. About half way thru 1st mowing it stared acting like it was starving for Fuel. Well, just the heat under the battery box was enough to let the Tygon tubing bend/kink on itself even tho I had a good loop. So I ended up putting regular rubber gas line on. Now it runs perfect! Tygon is great for Weedeaters and 2 cycle equipment, but I wouldn't use it on a Tractor!
Here are some pics!07-17-12_0834.jpg 07-17-12_0841.jpg 07-17-12_1046.jpg fuelpump.jpg
  • Bolens 1000, olcowhand and middleageddeere have said thanks
#2 olcowhand OFFLINE
  • 42,407 Thanks
  • 31,803 posts
Posted July 26, 2012 - 03:52 PM
I've used a pump like that before & got years of service. I've been using Mr Gasket 42S pumps the last few years & like them really well also. Thanks for the Tygon tip.
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,109 posts
Posted July 26, 2012 - 08:27 PM
Glad to hear it's back up and running, bud! Are you getting some seat time lately? Any 3 point work? Rear blade, front blade?
#4 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted July 26, 2012 - 08:31 PM
Not much Scott. Hot and dry, took over 2 weeks for the grass to get shaggy enough to mow. Got a little dirt work to do, just can't get the blade on with 1 hand. Maybe in another week or so I can use it more.
#5 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,229 Thanks
  • 1,083 posts
Posted July 29, 2012 - 08:54 AM
I've been thinking about one of these pumps for my 216 glad to see it's a pretty straight forward installation. :thumbs:
I'm guessing these pumps are pretty close in pressure output as to what the stock kohler pump puts out? In other words there is no issues with the pump overpowering the float needle?
#6 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 29, 2012 - 10:09 AM
Nice fix, where did you get this pump? If you don't mind me asking, how much? How about that Mr Gasket 42S pump?
#7 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted July 29, 2012 - 12:23 PM
Piggy, it only has 2-3 psi, so should be fine.
I got my pump at my local NAPA. Checked our Auto Zone and O'Reilly's and they didn't have it or the Brand Daniel is using.
Cost was $48.99.
  • Bmerf and pigsitter have said thanks
#8 pigsitter OFFLINE
pigsitter
  • 1,229 Thanks
  • 1,083 posts
Posted July 29, 2012 - 02:10 PM
Thanks for the info sonny,at that price it's not much more expensive than the aftermarket mechanical kohler pumps.
#9 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted July 29, 2012 - 03:27 PM
And I didn't have to take it apart! Still have a hurt hand so I did it, basically with one hand!
