My Serious Etank
22 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted July 26, 2012 - 08:42 AM
Was looking for something large enough so I could put my larger pieces into it......yes it is an over kill.....but I can get a good bit of parts in it at one time!! The larger pieces of flat metal annodes have been the ticket.....the only way to go....I hardly take them out....just use a piece of 2x4 to scrap them clean and keep going.
Just a peak of what I am working on. That is the bush hog dump cart in the tank.
Edited by sacsr, July 26, 2012 - 09:06 AM.
#2 KennyP ONLINE
  • 37,530 Thanks
  • 45,524 posts
Posted July 26, 2012 - 08:50 AM
I have taken a junk piece of iron and reversed the connections so it draws the crud off the anodes. Seems to have helped.
  • Texas Deere and Horse and sacsr have said thanks
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 26, 2012 - 09:22 AM
Wow that is quite a E-Tank. How often do you have to change out the solution?
#4 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted July 26, 2012 - 09:27 AM
is that a kid pool?
#5 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted July 26, 2012 - 09:53 AM
Flat Metal Anodes! I had been wondering what to do with a pile of old & mangled lawnmower blades. Once you see it, it seems so obvious.
#6 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted July 26, 2012 - 10:00 AM
It is a horse/farm watering tank....I think it holds about 600 gallons. I put it on a slope in my yard so I did not have to fill it up completely....the rain so far has been keeping up with the evaporation. I have had it for about a month.....will keep the same water in it as long as it keeps working. I may try an old pool hand screen to see how much stuff I can get out of the bottom. I was lucky to find the tank down the road for $100.....they are around $350 new.......my wife really loves the back yard ornament! :laughingteeth: No problem putting a frame, cart, etc in..
#7 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
That is quite the Etank! Roughly how many gallons does it hold?
EDIT: We replied at the same time. Lol. 600 gallons is pretty big! I would imagine you could fit a lot in there!
Edited by Ryan313, July 26, 2012 - 10:03 AM.
#8 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted July 26, 2012 - 10:11 AM
Sweeeet! Never thought of using a pool or other large tank. Being able to submerge an entire frame or cart body must be nice. How much current are you running?
  • sacsr said thank you
#9 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted July 26, 2012 - 10:18 AM
I'm thinking of using one of these to make one... I can get them locally for $100. 275 gallons, 40"x48" and they have drain cocks in the bottom.
#10 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted July 26, 2012 - 10:46 AM
I had bought a bigger charger thinking I would use the more amps.....but then decided this was a whole lot of area for things to go wrong. I ended up using a standard 2/6 amp charger.......I have used both 2 and 6 amp with good success. Keep in mind, my yard is fenced, my kids are in their 20's and gone, so I feel pretty safe using it.
I just got lucky finding this farm watering tub.......
#11 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted July 26, 2012 - 10:49 AM
I've got a new bigger tank too, but not put it to use yet. It's the bottom part of a molasses lick tank. About 5 to 6' across and a couple feet deep. Not sure how much it holds. That is a big e-tank ya have Scott!
#12 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted July 26, 2012 - 10:53 AM
I've used a 100 gal stock tank for mine.
#13 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted July 26, 2012 - 11:36 AM
This reminds me of a question I had when I was setting up my little tank. What if a bird thinks it's a bird bath and lands in it? Will anything happen, or does it have to be touching anything specific?
#14 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted July 26, 2012 - 11:58 AM
"Bird on a wire" unless he touches both the anode & water at the same time. I doubt it would kill a bird anyway.
#15 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted July 26, 2012 - 12:52 PM
That is a big tank. I recently gave my brother two of those poly tanks like twostep showed as I didn't think I would ever use them. Now I think I'll take one back.
