My 126 Wont Move
7 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted July 25, 2012 - 05:44 PM
it has a 124 rear in it i fired it up today to get better access to change the gear oil and it wont move. when i let the clutch out it stalls any ideas??
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted July 25, 2012 - 05:54 PM
Rearend locked up? Try jacking it up and turning a wheel. Does it stall when you let the clutch out in nuetral?
Edited by LTD, July 25, 2012 - 05:56 PM.
#3 KennyP ONLINE
  • 37,409 Thanks
  • 45,459 posts
Posted July 25, 2012 - 05:55 PM
Is the brake stuck on?
#4 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted July 25, 2012 - 05:59 PM
Ok, stupid question time! Did you KNOW that it worked before you put it in? If you knew it worked, I would check the clutch setup and all of that stuff first. Something could be catching or you might have skipped something. My 124 had the transaxle swapped because it would jam. My Dad and I put in one that had a creeper on it and the creeper gave me trouble so it was switched yet again and now it is fine. Neither of the two replacements were from 124 cubs so I don't think there should be a problem there.
#5 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted July 25, 2012 - 07:14 PM
it was the clutch mounting bracket that was bent out of shape and binding up so i hammered it back into place until i figure something out. but now it will only run for short periods of time before it shut off. its acting like its running out of gas but theres plenty in the tank
#6 KC9KAS OFFLINE
KC9KAS
  • 5,324 Thanks
  • 4,670 posts
Posted July 25, 2012 - 07:40 PM
Make sure the fuel cap vent hole is open so air enters the tank as the fuel is being used.
  • backwoods said thank you
#7 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted July 25, 2012 - 07:54 PM
If it sounds like it is running out of gas, clean the carb, replace any filters and make sure all fitting and lines are cleared out. Should fix your problem. I am glad you got it moving!
#8 KennyP ONLINE
  • 37,409 Thanks
  • 45,459 posts
Posted July 26, 2012 - 07:21 AM
Might want to check if something is floating around in the gas tank.
