Wheel Horse Transaxle Rebuild Help
6 replies to this topic
#1 jrk OFFLINE
jrk
  • 43 Thanks
  • 95 posts
Posted July 24, 2012 - 10:42 PM
I pulled the trans apart (1989 Wheel Horse 312-8) to inspect all the gears, clean the internals, remove a piece of broken dipstick and replace the snap rings, oil seals and bearings as a preventative measure. However, after looking through the 6/8 speed Unidrive manual - I've found that they do not publish the torque specs for the 4 bolts that hold the differential carrier together.
Can someone verify the torque specs for these bolts? Also do they recommend a "red" Loc-Tite for these bolts since they don't have a split washer to keep them from backing out? The bolts that I'm talking about are Part #65 on the diagram linked below:
http://www.partstree...1-07R10008-0003
Also before I start putting it back together does anyone know if the 1st / Reverse gear (#30) is bigger or smaller than 2nd / 3rd gear (#29). From what I remember the 1st / Reverse gear was bigger and that is the way it appears on the diagram below:
http://www.partstree...1-07R10006-0002
However, usually a larger gear on the input shaft would cause a faster speed so I just wanted to check and see if anyone else might know.
Thanks!
#2 JDBrian OFFLINE
  • 9681 Thanks
  • 14162 posts
Posted July 25, 2012 - 05:01 AM
Can't offer specific help but in general the size and grade of the bolts will give you a good idea of how much to torque them. Also, if that same rearend is used in other equipment you might be able to get the torque speccs from a service manual for that equipment.
  • jrk said thank you
#3 KennyP ONLINE
  • 52484 Thanks
  • 53088 posts
Posted July 25, 2012 - 05:13 AM
Here's a torque chart for bolts:
#4 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted July 25, 2012 - 08:07 PM
I had to rebuild the diff in my hydro transaxle on my D200. I went with grade 9 bolts and lock nuts and used red loctite. There were no torque specs that i know of, so just try to keep them evenly torqued.
I cant speak for any other WH transaxle but on the d series there is a problem of the bolts shearing and dropping the pieces into the case. There is no room between the diff bull gear and case so when the big pieces get trapeed between the two the case looses and cracks. Thats why its recommended to go to grade 9 nuts and bolts for d series.
#5 GWest OFFLINE
GWest
  • 703 Thanks
  • 650 posts
Posted July 26, 2012 - 06:10 AM
From service bulletin #273
2.1 When servicing an 8-pinion differential (using 3/8-16 hardware), always replace the
original nuts. Order P/N 108881, which are supplied in a package of four for your
convenience. If the bolts require replacement, be sure to use only Grade 8 or better quality.
Torque value is 30-35 Ft. Lbs.
Garry
  • caseguy and jrk have said thanks
#6 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 18861 Thanks
  • 11842 posts
Posted July 26, 2012 - 07:19 PM
Doesn't it matter what they are threaded into? Steel, cast iron, aluminum???
#7 KennyP ONLINE
  • 52484 Thanks
  • 53088 posts
Posted July 26, 2012 - 07:37 PM
That's probably for a bolt/nut combo. I pulled it from a manual.
