Ford Yt16h Hitch
9 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 24, 2012 - 07:45 AM
has anyone put a 3pt or sleeve hitch on a ford/lawn boy yt16h? if so could you please post pics for me to see. i want to someday get a small plow or maybe a rototiller for it and go to a plow day .
is this tractor sturdy enough for this kind of work?
#2 KennyP ONLINE
  • 40,123 Thanks
  • 46,764 posts
Posted July 24, 2012 - 08:11 AM
I don't think it has a strong enough transaxle for a plow. It's a Peerless 1329. The rototiller for it is only 26" wide.
#3 JDBrian ONLINE
  • 9,642 Thanks
  • 14,158 posts
Posted July 24, 2012 - 09:59 AM
If it really is a 1300 Peerless then that rear end is not rated for ground engaging equipment and you would probably break something if you tried to plow with it. That is one of the differences between a GT and a lt or in this case YT tractor.
#4 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted July 24, 2012 - 10:11 AM
I have a yt16 and broke the axle just pushing snow. It was a heavy wet snow and had tire chains on.
I attempted to weld it back up and it pulled a little, so it wobbles. I just use it for a spray buggy
#5 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 24, 2012 - 12:00 PM
ok thanks all
once i get it running and use it for a bit i may try and sell it and find something that will do so real work.
i should be getting a OEM ignition module hopefully sometime this week.
#6 daytime dave OFFLINE
  • 4,935 Thanks
  • 6,579 posts
Posted July 24, 2012 - 01:02 PM
I have the same issue with my YT18h. It is a great lawn mower, but not enough for much else. Accessories are near impossible to find in my experience. Still, it pulls the garden cart at harvest time.
#7 dogsoldier ONLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 24, 2012 - 01:57 PM
i have a wheelhorse and a mtd yard machine that i can use to pull a yard kart with. i think ill use it for a while and sell it maybe next spring and find something else. but first i need to get this thing running right.
#8 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 24, 2012 - 09:02 PM
Sure wish I could find a plow for my 195,, I am sure it will do the job if I could find the stuff I need for it,,,,
#9 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted July 31, 2012 - 10:54 AM
I have seen several CAT0 3 point plows on the KC craigslist. I'm not into gardening that much, so I have not bought one for my 195.
I have built a front dozer blade, rear angle blade, box blade, rear slip scoop and pallet forks (carry all). most of which were built from free rusty steel plates I saved from the scrapper. I didnt take the time ot prep and paint any thing, so they aint pretty but they get the job done
  • Russ said thank you
#10 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 31, 2012 - 12:14 PM
I not doing a lot of plowing myself rat88 but would be nice to have it for when I want to brake some dirt loose,, I built something to brake dirt an mounts on my fork lift I built,, Right now I am makeing a bigger one so it will be as wide as my 195 so it will work alot better,,
