What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3396 replies to this topic
#391 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted July 21, 2010 - 11:13 AM
Piddling with the Ford. The valves came in today, but not sure if I'll have time to get her fired today or not. Will try! If I do, I'll get video.
#392 tranders OFFLINE
tranders
  • 9 posts
Posted July 22, 2010 - 09:46 AM
Mounted the snow blade on the Raider 10 yesterday. Trying to get everything lined out now that way when the snow starts flying I'll be ready.
#393 kingkw OFFLINE
kingkw
  • 1 Thanks
  • 10 posts
Posted July 28, 2010 - 07:10 PM
I used my tractor to move two loads of firewood and cut some of the grass. It was a good test since I had to put new power steering hoses on it yesterday. Good to see that after replacing the second one I don’t have any leaks under the tractor. I tried to replace only the one that was leaking, but after the flexing that was needed to replace the rear one I found after putting it all back together that now the front one is leaking also. So it was back to the hydraulic parts store to have them make another. Slowly but surely getting all the bugs worked out of the tractor.
#394 MH81 OFFLINE
Posted July 31, 2010 - 08:43 PM
Started taking apart those old discs to modify for sleeve hitch. Gotta finish it tomorrow (In-Law's reunion this afternoon). Kids got to play with all the cousins they live 1/2 hour from & never see.
#395 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted July 31, 2010 - 09:15 PM
Today, I put the finishing touches on my Wisconsin engine.
Video and pics are in the Bolens Forum :D
#396 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted July 31, 2010 - 10:19 PM
Dropped the 3 point deck and mounted the plow with a new cat 0 hitch and did coarse adjustments.
#397 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted August 01, 2010 - 09:17 PM
I cut down and draged a few trees with my GT6K. Worked like a dream. Now I wonder what this thing will do in low gear. Imagine what my SS12 is gonna be able to pull, I cant wait.
#398 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted August 01, 2010 - 09:28 PM
Welded a support bracket to the Ford 165's muffler I built. Then went to move a MF12 carcass & blew a hose on my FEL mounted on my 1655. Later in the early evening, I rushed to get the yard mowed before dark & "thought" I had enough diesel in the Kubota....wrong! Took forever to get it bled & fired up, but did, and got the yard finished. Wish it had a low fuel indicator light!
#399 mjodrey OFFLINE
  • 2,356 Thanks
Posted August 02, 2010 - 05:01 AM
Well yesterday I hauled a couple trailer loads of brush with the Massey 1655.
#400 MH81 OFFLINE
Posted August 03, 2010 - 10:43 PM
I had to postpone any play time to replace the water pump on my Massey-Harris 81. Dad & I rounded all of his extras up & looked them over... the best feeling one had the right hole pattern & we bolted it on. Then when I tried to put the fan on, it was hitting the top tank on the radiator. Come to find out The center shaft was a full inch higher (dunno how I missed THAT) took it back off & took our 2nd choice. By this time we're getting pretty good at fitting in the pump in & we filled it & drove it before putting the hood back on. Not 1 drop... tomorrow's the parade. Whew. Maybe this weekend I'll get the chance to play with the Craftsman again. LOL
#401 caseguy OFFLINE
  • 1,628 Thanks
Posted August 04, 2010 - 06:40 PM
I had one of the big toys out today! I rolled the '52 VAI over to the neighbors house to fetch their JD L130. It seems that the front axle broke (see pic!)and the wheel bearings were...GONE...on the left side! They are very nice people and they usually call me when they need something mechanical done. I'm happy to do it for them as it's priceless to find good neighbors like them.
#402 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted August 05, 2010 - 07:55 AM
Yesterday I got the south section of the yard mowed with the craftsman.
Then I took time to look at th ford. it hadn't been running good and I was afraid to use it. Pulled the plug and it was very dirty (tractor uses some oil). Cleaned the plug and it's running like it should.
After that I still had a little time so i pulled the head on the 16 hp Briggs that goes in my MTD 990. cylinder walls look good, Piston had 020 stamped in the top so i am assuming that it has been rebuilt at least once. Valves look cruddy. This motor smoked more that I would like so that why I was going to rebuild it. I might be able to hone it and just put in new rings. I will try to get picture tonight for my rebuild thread.
#403 brzezinski01 OFFLINE
brzezinski01
  • 4 Thanks
  • 73 posts
Posted August 09, 2010 - 02:08 PM
mowed the grass at my grandmas church with the JD 212. working on being able to mow with my Bush Hog d4-10 by wednesday.
#404 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted August 09, 2010 - 02:22 PM
Friday evening I finished mowing the yard and then got out the ford and the tandem lawn sweepers. Managed to get 70 % of the yard swept.
here is a photo from last year when i first set up the tandem lawn sweepers.
#405 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 09, 2010 - 07:40 PM
Today I trimmed some branches then hauled them away with the 1050 with it's "new engine" :bounce:
