What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3297 replies to this topic
#3286 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted July 25, 2017 - 08:21 PM
Used the 1655 loader to pull my boat out after some lengthy work. Hoping got have it in the water this weekend. The crappie are already lining up in anticipation of my arrival.20170724_191053.jpg 20170724_191028.jpg
  • MFDAC and CRFarnsworth have said thanks
#3287 KennyP ONLINE
  • 34,189 Thanks
  • 43,310 posts
Posted July 30, 2017 - 03:43 PM
I got Alice out and hooked up the cultivator. Aaron has a food plot going out back and I wanted to see what would happen. One pass later and I had bent the cultivator again! This thing is junk.
So I came back up and hooked the disk up! Aaron's Dad has used his larger Kubota with a tiller to tear the ground up. Aaron, in his wisdom, used the Kubota and box blade to level things out, then pulled a set of old bed springs over it to smooth. He packed it all back in. Tight. An hour later and dropping the disk a half inch at a time and I got this.
  • CRFarnsworth, propane1, toppop52 and 1 other said thanks
#3288 Greasy6020 OFFLINE
Greasy6020
  • 1,036 Thanks
  • 983 posts
Posted July 30, 2017 - 09:49 PM
Taught my cousin about Mexican overdrive.
Worked on my food plot.
Discovered that the roper rt16 is too light in the rump to pull the spring tooth harrow
Pulled the disk w/ 2 cinder blocks on it with the moto mower and encountered belt slippage (belt was screaming) issues in the hill on my food plot
Went off-roading on the moto mower till I decided the skeeters were too bad... went down a trail I started but never finished
Felt the poor roper rt16s pain when my cousin socked it into gear without the clutch... he knew I was MAD judging by the flying hitch pin and stream of cursing n cussing he never heard before😂
Busy day, now I have a wicked sunburn😂
  • toppop52 said thank you
#3289 olds45512 ONLINE
olds45512
  • 1,112 Thanks
  • 567 posts
Posted August 07, 2017 - 01:53 PM
I tore down my old porch and had to move the old wood outback. The first pic is of the frame I made to hold the wood, it's screwed to the poly cart for stability. The second pics show it loaded with wood, I had double this amount of it before I moved it but the Cub 1211 handled it with ease. When everything was cleaned up I mowed with the 1211 and luckily didn't get any nails in my new tires.
  • KennyP, toppop52, Mark 149 J. and 1 other said thanks
#3290 toppop52 OFFLINE
toppop52
  • 4,566 Thanks
  • 4,282 posts
Posted August 07, 2017 - 03:57 PM
Mowed with the new to me Kubota, looked at the burned out hulk of the CC 3208.
  • KennyP and ShotgunWedding have said thanks
#3291 ShotgunWedding OFFLINE
ShotgunWedding
  • 117 Thanks
  • 48 posts
Posted August 08, 2017 - 07:38 AM
Clipped and hauled out year-old raspberry canes.
  • propane1, toppop52 and olds45512 have said thanks
#3292 olds45512 ONLINE
olds45512
  • 1,112 Thanks
  • 567 posts
Posted August 08, 2017 - 07:43 AM
That's a sweet cart! Where'd you get it?
  • propane1, toppop52 and ShotgunWedding have said thanks
#3293 ShotgunWedding OFFLINE
ShotgunWedding
  • 117 Thanks
  • 48 posts
Posted August 08, 2017 - 08:17 AM
Had it made for me.  Pretty pricey but worth it.  Had it painted in IH Red.
They are trying to sell more now, always made plastic tub ones, but I asked if they could make a metal one.  It was winter and shop was slow, they knocked it out of the park!!
They also sell the best SCUT cultivator I've seen, Cat 1 and a wicked lawn roller that blows away competition.  Again...pricey stuff but quality is top shelf.
www.marketfarmequipment.com
  • propane1 and toppop52 have said thanks
#3294 toppop52 OFFLINE
toppop52
  • 4,566 Thanks
  • 4,282 posts
Posted August 08, 2017 - 10:32 AM
Sweet tow cart!
#3295 ShotgunWedding OFFLINE
ShotgunWedding
  • 117 Thanks
  • 48 posts
Posted August 08, 2017 - 08:59 PM
Alice cuts a sweet silhouette!!!
#3296 olds45512 ONLINE
olds45512
  • 1,112 Thanks
  • 567 posts
Posted August 15, 2017 - 06:21 AM
There is a section of my yard I've neglected to mow the last couple times because I was in a hurry, I finally had time on Saturday. Here's a short video of my Cub Cadet 1211 in action, the grass was 8" tall and when I was done the clippings were about 4" thick. This is a 44" deck running gator blades.
Edited by olds45512, August 15, 2017 - 06:23 AM.
  • toppop52 and Mark 149 J. have said thanks
#3297 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted August 15, 2017 - 06:45 PM
It didn't even sound like it was breaking a sweat cutting that grass!
#3298 olds45512 ONLINE
olds45512
  • 1,112 Thanks
  • 567 posts
Posted August 15, 2017 - 07:06 PM
It has over 1100 hours on it but the 12hp runs strong, it's hard to beat a k series Kohler.
