What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3348 replies to this topic
#3121 jimbobbillyray ONLINE
jimbobbillyray
  • 2,703 Thanks
  • 2,701 posts
Posted January 08, 2017 - 09:54 AM
i tried pushing some snow the other day, but.....  picked up a new to me snowblade for my J D 420 this last summer, got it all hooked up and went out to push snow in the driveway a couple days ago.  Second pass and I noticed hyd fluid on the ground.  Dang it!  I broke the back fitting on the lift cylinder...when I raised the blade it hit the bumper and cracked it.    this 420's bumper has the cutout to allow space for that fitting, but it was turned up instead of to the side.....  I will replace the fitting and turn it sideways this time......I finished out the driveway with my snow shovel.....
Edited by Delmar, January 08, 2017 - 10:00 AM.
  • KennyP, propane1 and holdenboy1960 have said thanks
#3122 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted January 08, 2017 - 12:15 PM
Have any more pics of the spreader on the back?
  • jimbobbillyray, diesel nut, toppop52 and 1 other said thanks
#3123 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted January 08, 2017 - 12:17 PM
It's a CargO-Mount spreader off a L-series JD mower I found on eBay.
#3124 toppop52 OFFLINE
toppop52
  • 4,910 Thanks
  • 4,564 posts
Posted January 08, 2017 - 12:23 PM
I just came in from 2 hours of plowing that white stuff, wind blows it right back where I've been. I got a wide path to the outbuildings, cleaned off the apron in front of the garage, made a few passes down the driveway, but the wind is covering up faster than I can plow, so I gave up before I got frostbite. Wind chill -6 when I started.
  • KennyP and jimbobbillyray have said thanks
#3125 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted January 13, 2017 - 09:33 AM
I've found the best time to grade the gravel drive is right after a freeze when it thaws, a rain helps too.
conditions were near perfect last night and it was above 50* so hit the drive with the old Sears. Man, this crush limestone packs like concrete in some places.
I may have to make a thread for your ideas about some type of new grade attachment. I have to go in reverse to dig with the teeth or box just bounces like crazy and does no digging.
How's this for counter weight? I didn't want to carry the bag of rabbit food from house to barn :rolling:
  • propane1, toppop52 and holdenboy1960 have said thanks
#3126 toppop52 OFFLINE
toppop52
  • 4,910 Thanks
  • 4,564 posts
Posted January 13, 2017 - 10:16 AM
I have a clam shell driveway and it's the same way.
  • TAHOE said thank you
#3127 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted January 13, 2017 - 10:53 AM
Look at your teeth! They are in backwards! The point is toward the back! Add some weight on top.
#3128 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted January 13, 2017 - 12:54 PM
They are backwards because I have to do it in reverse. It doesn't matter if I turn them around and add weight, it still bounces like crazy. I'm thinking part of the problem is no down pressure to hold it down and if I put too much weight on it, then I cannot manually lift it.
If I would just get my MF1855 running with the hydro 3pt :wallbanging:
  • limebuzz and holdenboy1960 have said thanks
#3129 toppop52 OFFLINE
toppop52
  • 4,910 Thanks
  • 4,564 posts
Posted January 13, 2017 - 04:15 PM
Can't you rig a cheap winch on it?
#3130 dropped82 ONLINE
dropped82
    Nut Case
  • 2,330 Thanks
  • 1,742 posts
Posted January 14, 2017 - 01:32 PM
You want me to come get it? That way you won't have to worry about it anymore.
Eric
  • limebuzz said thank you
#3131 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted January 17, 2017 - 05:35 PM
I got to use Alice some today. Aaron wanted to level his shop floor better (it's a dirt floor). Had a good amount of drop side to side. So I hooked the box blade up and we got after it. Ended up taking the high side down about 6-7". to level it. Fun working inside a building, but we got it done.
Aaron shot a couple short videos and here's a couple pics.
  • jhn9840, limebuzz, MH81 and 7 others have said thanks
#3132 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 18, 2017 - 07:07 AM
https://youtu.be/HyoimP120EE
https://youtu.be/o8TUqv48g5s
Very nice Kenny.
#3133 propane1 ONLINE
propane1
  • 8,223 Thanks
  • 3,964 posts
Posted January 18, 2017 - 09:35 AM
My homemade rear box blade does the same thing, digs going backwards, wont dig so good going ahead. its just the set up of the linkage I think. My ford has down pressure, and doesn't help. Front dozer blade same thing, blade digs going ahead ,but not backing up.  Just a thought.
Noel
Edited by propane1, January 18, 2017 - 09:39 AM.
#3134 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted January 18, 2017 - 10:25 AM
Noel
If you lengthen the top link, the back will dig in. Shorten and it digs going forward. Post a pic of it!
  • propane1 said thank you
#3135 propane1 ONLINE
propane1
  • 8,223 Thanks
  • 3,964 posts
Posted January 18, 2017 - 10:39 AM
Sleeve hitch, not 3 point, Kenny.
Noel
