What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3371 replies to this topic
#2896 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 16, 2016 - 07:32 AM
2 days ago i started mowing the property out bush with the JD Sabre 2002 ,cutter belt come off & took chunks out of it so ended up doing the rest with the MTD gold series 2001
 some 1 hit a small Kangaroo on the road , been there for 4 abouts days & was on the nose so i used the Rancher 2 with the push blade & pushed it further up the road side away from the road gateway so i had more fresh air when opening & shutting the gate otherwise just moved scrap around with the Rancher 2
Shane
Edited by holdenboy1960, April 16, 2016 - 07:33 AM.
#2897 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted April 16, 2016 - 03:18 PM
I plowed at Pa plowday.   :rocker2:
  • KennyP, CRFarnsworth, WrenchinOnIt and 1 other said thanks
#2898 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,853 Thanks
  • 4,347 posts
Posted April 16, 2016 - 04:08 PM
I mowed wet grass, drizzle right now but expecting 3-5 inches through tomorrow. Surprising little needed scraped of the bottom uf the deck afterwards.
  • KennyP and MolonLabe have said thanks
#2899 shorty OFFLINE
shorty
  • 5,274 Thanks
  • 5,161 posts
Posted April 16, 2016 - 04:12 PM
I let mini me play in the garden with the Gravely. Still plenty wet to till, so we ran the cultivater through it to break it up again. A few more days and it should be good.
Edited by shorty, April 16, 2016 - 04:21 PM.
  • KennyP, CRFarnsworth and MolonLabe have said thanks
#2900 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,545 Thanks
  • 961 posts
Posted April 16, 2016 - 04:59 PM
We picked up the sticks , then rolled the lawn with the 1500 pounder, sun and wind drying it out ,no rain in forecast maybe a grass mowing coming, low spots still really wet , but it needs mowed
  • CRFarnsworth, jpackard56, toppop52 and 2 others have said thanks
#2901 Fordman1955 OFFLINE
Fordman1955
  • 9 Thanks
  • 20 posts
Posted April 16, 2016 - 08:40 PM
Worked on the garden with the new lgt145 and rear tiller. Doesn't seem to have the power it should for 14 hp. Mowed with the cc1282 . Pulled the lawn sweeper with the Ford lgt 100.
#2902 crossarm OFFLINE
crossarm
  • 58 Thanks
  • 42 posts
Posted April 17, 2016 - 06:51 AM
Spread a load of gravel with the 430
#2903 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 17, 2016 - 07:11 AM
Pulled the plow off the 300 JD yesterday an put the tiller on.
Sent from my SM-S820L using Tapatalk
#2904 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 19, 2016 - 06:05 PM
Tilled the garden an blew a hydraulic line
  • limebuzz, Alc, WrenchinOnIt and 2 others have said thanks
#2905 toppop52 OFFLINE
toppop52
  • 5,013 Thanks
  • 4,628 posts
Posted April 19, 2016 - 08:47 PM
Rode around on the Murray after adjusting the valves.
  • backwoods said thank you
#2906 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,573 Thanks
  • 2,106 posts
Posted April 19, 2016 - 09:04 PM
Mowed the yard with a J.D. 70, 7h.p.engine, 34" deck
I finished this tractor overe the winter. Tested it a couple weeks ago.   Fixed a couple small problems.
Today I put it to work and mowed the entire yard.
It mowed nice and even.  I was pleased with the cut.
The bad part was 2nd gear was too fast, and 1st gear was slooooowww!
It took almost twice as long to mow the yard as it would have with my regular mower.  18 h.p. engine 46"deck.
The good part is that it rides well and turns easy and tighter than the bigger mower.
I think the wife Is going to like this one.
  • limebuzz, Alc, MFDAC and 6 others have said thanks
#2907 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted April 20, 2016 - 02:45 PM
Mowed the yard on Saturday with the 15HP 42" deck on my craftsman rider. All weekend was yard and garden. After yard cleanup was done I pulled out the sears custom 10 HP and started plowing the garden. Ground was just right for a good furrow so I did most of the 1/2 acre garden with the plow first. Then I thought I need more seat time sooooo, I got out the 12HP suburban and I hooked up the roto tiller and went back over the fresh turned ground with the tiller to get ready to plant. Man that garden looks good now for sure!!!! I'll get some picks and post in the next couple of days. Also played hooky from work on Monday as the weather was beautiful and I planted 2 rows of asparagus in my newly plowed garden. :)
  • limebuzz and MFDAC have said thanks
#2908 MFDAC OFFLINE
MFDAC
  • 3,152 Thanks
  • 1,568 posts
Posted April 20, 2016 - 09:42 PM
Mowed the front yard and part of the back yard after work tonight with the MF12G. I have a side job starting so I couldn't do the whole yard.
DAC
  • limebuzz said thank you
#2909 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted April 21, 2016 - 09:55 AM
Got BIL's Kubota running. Been through all the fluids and filters, tires holding air now, coolant stays in currently, still need new top hose. Still needs some hoses replaced on hydraulics, also some change in connections - the direction of travel with hyd. controls is wonky, and several bushings and pins in PTO for tiller, but it's working :rocker2:
Started in small garden seemed to work pretty good
and cleaning up a trench line near small pond.
Sorry video failed...
You can see what is left of my canvas shed after those 60+ mph winds when we were at Daniel's plowing
Edited by jpackard56, April 21, 2016 - 09:59 AM.
  • limebuzz and backwoods have said thanks
#2910 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted April 22, 2016 - 06:40 AM
Still tilling some areas around the place that I had moved fill to with bigger tractor.SANY0094.JPG
  • limebuzz, KennyP, backwoods and 1 other said thanks
