What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3396 replies to this topic
#2476 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted June 11, 2014 - 07:10 AM
Actually, I sprayed more than "one" weed! :smilewink:
Kinda hard to spray just one!
#2477 UncleWillie ONLINE
  • 15,676 Thanks
  • 8,763 posts
Posted June 11, 2014 - 10:20 AM
depends on how accurate you are.
#2478 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,715 Thanks
  • 2,160 posts
Posted June 11, 2014 - 07:07 PM
I had been mowing about twenty minutes with my big mower when my phone started ringing.  I shut the mower off to answer a wrong number.  The mower wouldn't restart.  So i went to the shop and decided to put my little Wheel horse to work.   She had been sitting all winter and spring.  Checked the tires, oil, and gas.  She fired right up and went to work.   Finished mowing my yard and the neighbors.  The little tractor did a good job.
The only other working mower is an old Springfeild rider....  it would have taken twice as long.
When the work was done the big mower fired right up!  Sometimes I swear they are alive!    Rick
  • twostep said thank you
#2479 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted June 12, 2014 - 01:20 AM
I am finally getting some serious seat time. Tilling the church garden (50 x 120 yards), mowing my yard, Parents yard, neighbors yard and mowing around the garden. Keeps me busy, but I love it!
Not pictured was a John Deere LT166 & LX280
Edited by A.C.T., June 12, 2014 - 01:25 AM.
#2480 Simplicity10 OFFLINE
Simplicity10
  • 1 posts
Posted June 14, 2014 - 06:03 PM
I hauled a huge trailer full of cord wood from neighbor with my simplicity
#2481 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,988 posts
Posted June 14, 2014 - 09:00 PM
I used one of my father's old Gravelys today, it was the only one with a rotary plow already attached.  I wanted to mound up around my potatoes before they got any larger.
When I pulled the tarp off the tractor, where it has been sitting since Dad's house sold, the gas tank was empty (which worried me) and had traces of water sitting in it.  I found some "Heet" water remover, filled the tank and added the "Heet" along with sea-foam and Stabil to the gas tank.  I removed the glass fuel bowl, cleaned all the crud out of it, put it back together, got the old gasket to stop leaking, then pulled the strap.  FIRST PULL, I had a running :worshippy1: Gravely!!  I love these old machines, they just keep running if you take any kind of care of them.
So I proceeded to use the rotary plow to mound up my potatoes.
#2482 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,988 posts
Posted June 14, 2014 - 09:01 PM
Also, I used my Massey 12 H to cut the neighbor's yard, my front yard, and the right-of-way along our little sub-division.
#2483 toppop52 ONLINE
toppop52
  • 5,273 Thanks
  • 4,770 posts
Posted June 15, 2014 - 12:31 PM
I sprayed another weed! Well, actually several weeds... :D
#2484 grnspot110 ONLINE
grnspot110
  • 4,162 Thanks
  • 2,649 posts
Posted June 23, 2014 - 06:28 AM
Yesterday we hauled four of them to a small show in Eagleville, MO, about an hour from home:
We got a little damp while loading, but nothing serious!  ~~  Lowell
#2485 toppop52 ONLINE
toppop52
  • 5,273 Thanks
  • 4,770 posts
Posted June 23, 2014 - 07:19 AM
I cut several trees and pushed them into the woods with my little Wizard bucket tractor and pushed several small ones over without bothering to cut them first. It's amazing the abuse these little tractors will absorb!
#2486 daytime dave OFFLINE
  • 4,845 Thanks
  • 6,545 posts
Posted July 13, 2014 - 11:39 AM
Yesterday I went to dad's and pushed his seeder around a little.  The wagon is full of feed sacks, but it also has the planter and related materials.  The 147 got mowing time.  All of ours wear their work clothes.
  • propane1 said thank you
#2487 toppop52 ONLINE
toppop52
  • 5,273 Thanks
  • 4,770 posts
Posted July 13, 2014 - 02:22 PM
Tractors are for working, that's what mine do, I trimmed some trees and pushed/hauled the brush away with the Wizard, after mowing with the Simplicity/Craftsman ZTR.
#2488 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted July 14, 2014 - 05:16 AM
Got the Toro out to mow the pasture. Had an issue with a belt. The green Kevlar belts aren't going to hold up to this set up. So I'll need to order new Toro belts. The PTO drive shaft is needing attention, so I ordered new u-joints and one splined end for it. That was $180. But it does a great job mowing and is fun, so well worth it.
#2489 Alberta Bolens OFFLINE
Alberta Bolens
  • 788 Thanks
  • 353 posts
Posted July 14, 2014 - 11:13 PM
Using a Bolens 1050 and cart.  Redoing flower beds so hauled rocks that we had around the edges away.  (when the wagon tires are flat.  Does that mean its over loaded??)   on return trip loaded split fire wood brought up to wood shed.
Used the JD 425 with 3 point itch to bring the boat around to the garage.
#2490 countryboy88 OFFLINE
countryboy88
  • 102 Thanks
  • 144 posts
Posted July 15, 2014 - 08:53 PM
Moved a little top soil from my driveway project. I was a little light in the front end, couldn't steer very well once I had it picked up, but I managed.  :smilewink:
Black line was the original grade.
