What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3239 replies to this topic
#181 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 520 Thanks
  • 473 posts
Posted April 15, 2010 - 09:44 PM
Well today I tested out the sleeve hitch I built I then put the backblade on and graded my buddys yard I then took the blade off and went over to my sisters and mowed her yard.
#182 Chuck_050382 OFFLINE
Chuck_050382
  • 273 Thanks
  • 1,498 posts
Posted April 16, 2010 - 07:20 AM
Got the garden plowed yesterday.
here are the pictures and video.
http://www.gttalk.co...a-838/#post6498
#183 robin OFFLINE
robin
  • 1 Thanks
  • 28 posts
Posted April 16, 2010 - 08:30 PM
i built a left side sheild for my mf8 and got the whole decal package in the mail today better hurry up and get it blasted and painted
#184 Guest_hooligan_*
Guest_hooligan_*
  • Guests
Posted April 16, 2010 - 10:12 PM
I put a new K341 in the MF1450, going to swap hoods also, so now my 1450 is a 1650. I got the steering column out of the MF14 and ready to install new column
#185 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 520 Thanks
  • 473 posts
Posted April 16, 2010 - 11:51 PM
Today I mowed my yard and the folks yard then I finished making a lift rod for heavier attachments. I then put the BIG TEN INCH on and tested it out and adjusted it.
#186 olcowhand OFFLINE
  • 37,229 Thanks
  • 30,214 posts
Posted April 17, 2010 - 07:43 PM
Did nothing with the tractor, but did some work on my Onan B48G 18hp that will go on my MF1655 w/FEL when finished. Got the block clear of gaskets, chased all the threads out, honed the cylinders & lapped the valves. Gonna do a good wash on the block, then start re-assembling it. Crank bearings are great, but got new cam bearings, piston rings, and all the gaskets I needed. Just finished turning some steel on my lathe into a cam bearing driver.
#187 tractormike ONLINE
tractormike
  • 165 Thanks
  • 1,488 posts
Posted April 17, 2010 - 08:10 PM
Today was the first mowing for me. I had to jump start the 112 John Deere. It sat all winter but just wouldn't start, battery was low. The charging system just doesn't keep up on it. I think the stator is getting bad. I mowed the flat yard up behind my house then brought the 112 down to the shop to change oil and check her over.
#188 Guest_hooligan_*
Guest_hooligan_*
  • Guests
Posted April 18, 2010 - 07:43 AM
You guys up north arre lucky. How many times to you have to mow, 2, 3 times, lol. I'm getting ready to mow for the 4 time and I'm behind due to monsoon seaon. The last two years have brought us close to 60 inches from January to July. The rain and lack of sun have caused gardens to wither, so I'm planting in the end of June, first of July. We rarely see a freeze till first part of December and it doesn't realy matter when the crops are mature as it does when there starts or flowering
#189 mjodrey OFFLINE
Posted April 18, 2010 - 07:55 AM
I mow on average around 30 to 35 times a season,sometimes I mow twice a week.
#190 olcowhand OFFLINE
  • 37,229 Thanks
  • 30,214 posts
Posted April 18, 2010 - 03:00 PM
Mike, we're about 5" behind normal rainfall. I don't like the trend I'm seeing either. Many parts of the country, like the NE are getting deluged as you. Then other spots are dry & can't pray rain in. That is exactly the weather pattern 2 & 3 years ago when we had drought here.
Besides Mike, I love mowing....when I don't get too far behind. I mowed some today, then worked on the Onan engine I'm rebuilding. Time to milk again, so see ya'll later!
#191 Chuck_050382 OFFLINE
Chuck_050382
  • 273 Thanks
  • 1,498 posts
Posted April 19, 2010 - 07:27 AM
Mowed and dethatched the yard sat and sunday. Broke a belt saturday, got a new one yesterday and got back to mowing.
#192 Chuck_050382 ONLINE
Chuck_050382
  • 273 Thanks
  • 1,498 posts
Posted April 19, 2010 - 07:40 AM
Also tore apart the carb on the craftsman to clean it since it was leaking gas into the oil.
Problem seems to be fixed now.
#193 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 520 Thanks
  • 473 posts
Posted April 20, 2010 - 01:43 AM
Didn't do anythging with the tractors today but I did fix a leaky lift pump and put the muffler back on yesterday, I had a stack on the 920 but the motor shakes too much and it broke the pipe right under my weld, hell it was too loud anyway with it on there. HOLY CRAP I just came to the realization that I'm getting old.
#194 olcowhand OFFLINE
  • 37,229 Thanks
  • 30,214 posts
Posted April 20, 2010 - 11:01 AM
Mowed yard with Kubota yesterday. On my full size MF1100 spraying corn today.
#195 mjodrey OFFLINE
Posted April 20, 2010 - 11:20 AM
Over the weekend I got my Kubota mower deck out and waxed, greased , and installed it back under the Kubota.Now I am already to mow as soon as the lawns dry up.
