What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3410 replies to this topic
#1876 JDGuy445 OFFLINE
  • 356 Thanks
  • 428 posts
Posted October 28, 2012 - 12:42 PM
Mowed leaves and fueled up yesterday.
#1877 Chuck_050382 OFFLINE
  • 275 Thanks
  • 1,498 posts
Posted October 28, 2012 - 08:42 PM
Today we cleaned out a flower bed and I used the ford lgt 165 and the trailer to haul it all off. After the work was done I took jenny and the kids for a trailer ride.
  • Texas Deere and Horse and twostep have said thanks
#1878 Texas Deere and Horse OFFLINE
  • 14,859 Thanks
  • 15,510 posts
Posted October 28, 2012 - 10:10 PM
Chuck, Nice shot of the family, thanks for sharing.. :thumbs:
  • Chuck_050382 said thank you
#1879 twostep OFFLINE
  • 1,987 Thanks
  • 2,538 posts
Posted October 28, 2012 - 10:35 PM
Did a little plowing this weekend :dancingbanana:
#1880 UncleWillie OFFLINE
  • 15,890 Thanks
  • 8,842 posts
Posted October 29, 2012 - 06:03 PM
Moved the quickly improvised chicken coop across the yard to the chicken pen with the Hemorrhoid and the trailer. . My wife started to build it then got frustrated and I went out and cobbled it together. It will do will I have time to rebuild it.
#1881 grnspot110 ONLINE
  • 4,230 Thanks
  • 2,669 posts
Posted October 30, 2012 - 04:38 PM
Used the 314 & 42" Huskee sweeper to pick up some leaves this afternoon.
Stock photo:
#1882 Buggyman OFFLINE
  • 42 Thanks
  • 94 posts
Posted October 30, 2012 - 11:32 PM
I hooked my 2418 economy to my generator/welder trailer and welded up some metal fences that had some rods with welds broken. We have a lot of sucker rod fences and horses and cattle trying to reach through or over sometimes break welds that were not as strong as they should have been in the first place.
#1883 olcowhand ONLINE
  • 41,898 Thanks
  • 31,637 posts
Posted November 01, 2012 - 11:00 AM
Went up to the plow day field area, and used the JB with the 12" plow to lay some drainage furrows in the adjacent flat field. Plowing the furrows all the way to the center drainage ditch allows for quicker planting in the spring. Was a bit muddy in some spots, but I got them in. Then I plowed a few more passes on the lower side of the plow day spot. If I get more time, I'll plow some more of it. There's about 1 1/2 acre left un-turned on the lower side. They are shorter passes.
#1884 nra1ifer OFFLINE
  • 674 Thanks
  • 1,531 posts
Posted November 01, 2012 - 11:33 AM
Filled the ag's on my PGT9000 and had enough junk antifreeze left to fill one turf tire that'll end up on the GT6000 for snow duty. Need to go by friend's shop to load up with more junk anti-freeze. Also put chains on that filled turf tire. I had recently acquired a brand new set of peerless chains via a CL ad. They fit very nicely. Filled the tires through the valve stem using Slime's adapter. It worked well. The turfs were easier to fill, since they are only 2-ply and easier to squash them a bit to suck the fluid into the tire. Still need to fill the tires on the Cub 123 and the Speedex. All in good time.....
  • 3,787 Thanks
  • 3,907 posts
Posted November 01, 2012 - 12:11 PM
Finally got to test the new tiller on the Ford 1500 last night(glad I stayed at 48" instead of going 60") It rides just off the governor. It was still a bit wet, but i'm hoping turning it last night will dry it a bit so I can till again tonght and get the garlic planted.
#1886 58pony OFFLINE
  • 2 posts
Posted November 02, 2012 - 08:49 AM
First I am happy to join this forum, and look forward to reading the posts and participating.
What I did to my tractor? Spent many hours trying to figure out how to install a plow to my Wheel Horse 800 Special. Got some help from others and found an assembly drawing, that led me to this forum. Hopefully it won't snow before I get all the parts and install them.
#1887 BairleaFarm OFFLINE
  • 1,354 Thanks
  • 1,783 posts
Posted November 02, 2012 - 01:01 PM
Used the charger to clean up and burn some brush. One of the trees exploded when it hit. Bark and branches all over the place. It did a great job. I'm so glad to have a hydro again.
Sent from my HTC One X
  • twostep said thank you
#1888 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted November 03, 2012 - 03:00 PM
Hooked the LA105 up to the lawn sweeper and cleaned up the last of the leaves. After that I hooked up the 420 to the LA105 and pulled it out of the muddy garden where I was dumping the leaves. Then I used the 420 to haul the bags of leaves from my BIL's (he brought me another truck load last night) out into the garden and opened them up.
#1889 larrybl ONLINE
    Texas Member
  • Site Supporter
  • 7,101 Thanks
  • 4,454 posts
Posted November 03, 2012 - 03:34 PM
Parked all of them in the shop so they can be locked up during my Week in Chicago next week. Work / training related.
  • 3,787 Thanks
  • 3,907 posts
Posted November 03, 2012 - 08:13 PM
Got the gardens tilled( pictures in Garden Section) moved 12 loads of dirt with the 3 point scoop, put the blade on and have about 20 more loads piled up to move.
It was in th low 50's today so was outside all day. Not many more of them in the future. Have to do all I can because it's getting close to time to mount the chains and blade for snow removal.
