What did you do WITH your tractor today? ie: plowing, hauling, tilling, etc.
3396 replies to this topic
#151 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 03, 2010 - 02:18 AM
Showed off the 920 to a few buddys and put a little wax job on it.
#152 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted April 03, 2010 - 10:51 AM
Tilled another pass in garden with the Bush Hog JBI, then transplanted 42 broccoli plants & about 50 onion sets.
#153 massey driver ONLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted April 03, 2010 - 03:40 PM
Didn't do much with the MF1655 other then start it up lift up the loader high enough to drill holes in the bucket so that I could mount the new tooth[tool]bar onto it.
#154 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted April 05, 2010 - 06:54 AM
Friday I moved some fire wood from where I had cut it last fall to where it should be stacked. I moved 3 loads this size.
#155 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted April 05, 2010 - 12:45 PM
That looks like some good firewood.
I didn't do anything with the tractors this weekend. I thought I was going to get to mow on Sunday but the grass just didn't grow enough to warrant a mowing.
#156 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 05, 2010 - 06:47 PM
This weekend I put the tiller on the 850 and tilled the garden. The next day I cut some trees and used the 1000 to haul the fire wood back. The Bolens definietly got a workout this weekend.
#157 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted April 06, 2010 - 07:32 PM
Tilled an area next to the new hay shed to level & sow grass seed. The got My Massey "2050" with 3pt blade on to smooth area where we ripped in electrical wire to hay shed. Needed smoothed up so I can mow.
#158 grand OFFLINE
grand
  • 2,043 Thanks
  • 2,015 posts
Posted April 06, 2010 - 07:54 PM
I got home from Charlotte this morning about 8 o'clock and knew that because of my hours left that I wouldn't have to worry about a work call tonight. Decided to finally change batteries between the 600 and the 800. When I put the battery in the 800 it started up just like it should. I backed it out of the shed and took it for a spin around the yard. The old gal sounded great.:smile1: I put the original battery out of the 800 on the charger for several hours and then put it in the 600. That little rascal fired right up ! It seems that the problem is a pull switch that was installed on the 800,if not left in the off position is just like leaving your key on. This must have completely drained the battery and caused our starting problems all along . If we had only known.:wallbanging: But it sure was great to know that both of these old timers are now ready to run.:bounce:
#159 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 06, 2010 - 08:47 PM
Good to hear the Bolens are working well for you:bounce:
#160 pulltilbroke OFFLINE
pulltilbroke
    MMMMmmmm DIESEL
  • 523 Thanks
  • 473 posts
Posted April 10, 2010 - 09:48 PM
Today I cleaned up and inspected the deck for the 920 and put it on then I mowed my buddys yard, my yard and the folks yard. Then I drug out the 1000 and pulled the deck off it and cleaned it up, then I put the plow on and some ags, still waitin for the battery to charge to get it runnin.
#161 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted April 11, 2010 - 12:53 PM
I mowed yesterday with all four tractors, I had to share seat time so one wouldn't get jealous over the other one. The 125 I need to adjust the deck so it cuts the same height as all the other ones, right now it is about an inch higher then the rest of them. I got the deck adjusted on the 147 and I also got the governor issues fixed. I had my earphones on and a set of ear muffs and that thing still made my ears ring mowing with it and the straight stack.
My favorite though to mow with is my Massey MF12, I just like the way you feel like you sit down lower and the bigger steering wheel, reminds me of when I had my Peterbilt and the long and low feeling. LOL The little MF8 did a great job as usual trimming. I made a quick video mowing with the 12 on almost 2 passes. I gotta upload it to youtube and I will post it in the Massey Forum. It is still striping the grass just as good as the neighbors exmark. :D
#162 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted April 11, 2010 - 01:59 PM
Mowed area around house with the Kubota G4200, then mowed the roadside with the Massey 1010. Before mowing with the Kubota, I modified the exhaust outlet. It went straight our the front, so under load, the smoke ended up in my face. So found an old Briggs header pipe, & slash cut end opposite the 90 degree bend, & she slid right inside the muffler outlet. Now the exhaust is directed 4 o'clock downward to the right. The smoke now goes to the side & out, and the small elbow clears the hold in the hood for engine access.
#163 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 11, 2010 - 08:28 PM
Today I used the 1000 to pull the trailer and pick up the branches from the trees I pruned
#164 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted April 12, 2010 - 07:11 AM
I finshed up my mowing yesterday with the craftsman, then changed the oil in the ford, remounted the sleeve hitch, and started plowing the garden.
I still need to build a lift bar of my sleeve hitch so I was using a piece of chain. I was really impressed with how well the Ford LGT 145 was able to pull the plow.
Edit: Here is a picture. I still have more plowing to do.
#165 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 12, 2010 - 09:36 AM
Awesome plowing pic! :thumbs:
Today the deck is going on the 1050 and I'll cut the lawn for the first time this season!!!!:dancingbanana::dancingbanana:
