Started Making My Potato Plow
14 replies to this topic
#1 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted July 20, 2012 - 10:50 AM
I was asking questions in a different post about what do you use walkbehind tractor for http://gardentractor...or/page__st__15
and a potato plow came up . I took this home made row marker that came with my DB 600 and a unknown plow which came with another . Cut where the row marker was attached . Then cut the plow shorter but had to make the opening a little bigger to fit the bar coming from the tractor hitch . Part of the plow will be used as "heal fin" is what Sears called it in their "adjustable foot " brochure Now I'm in the process of figuring out how to attach the plow share I would like to make it centered and also removable too . And the heal fin will need to be adjustable too , And ideas will be appreciated , thanks Al
  • propane1 said thank you
#2 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted July 20, 2012 - 11:09 AM
I can't help with the ideas, unfortunately. It looks like you are already getting a good start on it! Keep it up!
#3 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted July 20, 2012 - 11:17 AM
The more I look at what Sears made I might be better just to try copying the way they did . Cut the adjustable part of the plow a little shorter and sandwich 2 pieces on either side so a plow bolt can go through the middle and would make adjusting easier .
#4 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted July 20, 2012 - 11:42 AM
Sounds like a neat implement you are build ing there, Al! Stand back and scratch your head a bit, might clear the muddy water!
  • Alc and propane1 have said thanks
#5 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted July 20, 2012 - 08:02 PM
Thought using a cultivator shank would work but not the correct angle and might not be strong enough anyway . Maybe just use the bottom of one and take another one apart and double the thickness and use the original beam that;s in the second picture Still need that "fin"
#6 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted July 29, 2012 - 02:09 AM
Adding rebar to the top and even the sides a bit will help loosen up the dirt and help separate the spuds from the dirt..
#7 Wheel Horse Kid OFFLINE
Wheel Horse Kid
    Certified Wheel Horse Nut
  • 213 Thanks
  • 817 posts
Posted July 29, 2012 - 09:36 PM
Don't have any suggestions either, but good luck with building it!
#8 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted July 30, 2012 - 05:19 PM
I saved some 1/2" rods from work but the steel is soft compared to rebar . A friend is going to look for some better 3/8 to 1/2" round stock that might be a better grade the what I have . Al
#9 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted July 30, 2012 - 11:13 PM
Smooth steel should be fine.. its just something to let the spuds ride up a bit more to loosen the dirt off of..
#10 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted September 16, 2012 - 07:08 PM
Never finished my plow , good thing lol , picked up this Sears 3-point one that someone added some kind of extension , not sure but I would like to make it bolt to the one I was making and maybe remove the extension try keeping it a 3 point it I fashion a spot for the top link , Al
#11 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted September 17, 2012 - 06:18 AM
That's a plus, Al! Not nearly as much work involved there.
#12 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted September 17, 2012 - 07:38 AM
Kenny it sure would have been easier if I didn't weld that other plow onto the DB front section lol , Al
#13 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted September 17, 2012 - 08:19 AM
I have faith in you, Al!
#14 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted September 18, 2012 - 06:04 AM
I think I'll finish the plow I started and use the new one as a pattern , should be able to swap the parts so I can use either , does anyone know why that new one was made with a extenision ? Maybe I should just keep it that long , could be handy for trenching or maybe some other uses ? Al
#15 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted September 18, 2012 - 07:25 AM
Maybe he wanted to see the plow better, so moved it back?
