"next" Ford Lgt 195
82 replies to this topic
#46 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 08, 2012 - 09:31 AM
I had to take my hood off so it won't get to hot inside,, I going to custom my muffler so it will be on the outside,, The muffler is the main thing that make my 195 hotter inside I think,, But I been useing my 195 when its 90 or better outside an that will get em hotter with covers on,, I going to try an cut out my side pannels like skyrydr2 did his,, That look sharp,,,,,
#47 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 14, 2012 - 09:26 PM
I am considering makiing more cuts in the side panels. Thanks Keith for the photos, look good. What enigine have you used?
#48 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 14, 2012 - 09:54 PM
Thought long and hard about the over heating issue. Looked through the collection and found this.
It an old header for a VW. Did this to it.
Cut a peice of pipe.
Welded it up.
It's a tight fit, but there is a quarter of an inch minimum clearance.
While I was at it, I took care of another possible heat issue. There was a gap between the shelf above the muffler and the motor.
Ran the machine tonight. Extra pipes made it quieter, Hope it works to keep the motor cooler.
Next, mow the yard tomorrow, Hopefully with the side panels and not UGLY.
#49 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted August 15, 2012 - 03:13 AM
Kubota D600, its a sweetheart! I absolutely adore my 165, it is powerful, smooth as silk and a real pleasure to operate . Hottest it has ever registered on the temp gage was 210 and that was mowing , too that seems to be the worst thing it does ? Tilling doesn't bother it and anything else I use it at maybe 1/4 throttle.
I like your pipes they look awesome! Get some header wrap and wrap the muffler and pipes too, it will also cut down the heat .; )
  • Bmerf said thank you
#50 KennyP OFFLINE
  • 40,207 Thanks
  • 46,805 posts
Posted August 15, 2012 - 04:09 AM
Neat exhaust! I think Keith's wrap idea might help some more. Don't want to cook the PTO.
#51 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 15, 2012 - 09:00 PM
Well she mowed purrddeee today.
Mowed for 1 1/2 hours, no issues. Temp 77 degrees. Opened hood after shut down. Still plenty warm in there. Had heat soak issues after shutdown, would not start ten minitues later without dumping gas down carburator, I believe the gas vaporized after shutdown. Think I will be looking for the exhaust wrap. Does anyone know if a cover is missing from this area?
Seems like a lot of hot air is entering right next to carb and intake.
Edited by Bmerf, August 15, 2012 - 09:09 PM.
#52 KennyP OFFLINE
  • 40,207 Thanks
  • 46,805 posts
Posted August 16, 2012 - 06:30 AM
I would think something would be there. Danged hard to find any info on these engines.
#53 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 16, 2012 - 10:32 AM
Yes there is a cover for that part of the motor,, I going out to get a pic for ya,,
Edited by Russ, August 16, 2012 - 10:55 AM.
#54 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 16, 2012 - 10:36 AM
I like the way you made the exhaust,, Thats cool,, But it looks like it would be pretty hot on the belt,, I going to run mine out the front where can put head light an turn em down,,
#55 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 16, 2012 - 10:56 AM
Here is the pic of what the cover looks like Bmerf
  • KennyP and Bmerf have said thanks
#56 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 16, 2012 - 10:58 AM
I don't have the lil side pannles that cover the side of the motor it self but sure like to find em,,,
#57 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 16, 2012 - 06:09 PM
Thanks Russ,
I bet there is suppost to be one on the other side also. Thought it was funny that there was nothing between the exhaust manifold and the intake manfold on mine. Will have to make a shield for both sides. I did not reach in to see how hot the PTO/belt was getting, figured it must be cooler than having the exhaust dump directly on it. Hard to tell from photo, but there is +1 inch clearance between belt and exhaust pipe.
By the way, I seen some engine side panels/tins on E-bay the other day. Search Kohler K532 Engine.
Edited by Bmerf, August 16, 2012 - 06:12 PM.
  • Russ said thank you
#58 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 16, 2012 - 06:32 PM
Here is the one I looked at:
http://www.ebay.com/...=item2c675fb194
Free shipping. Hope the link works never tried it before.
Edited by Bmerf, August 16, 2012 - 06:33 PM.
#59 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted August 16, 2012 - 07:47 PM
Yea there is a cover on the other side also,, I will get a pic if ya want me to for ya,,, An thanks for that link for the tin wear,, I will try an get it as soon as I can,,,
#60 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 16, 2012 - 09:19 PM
Thanks Russ, That would be appriecated.
