"next" Ford Lgt 195
82 replies to this topic
#16 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted July 22, 2012 - 10:00 AM
Here are the pics as promised. I saw no need to get the left side as it is the same as the right. I did state above that the left side went behind the steering arm. That is incorrect, it goes over.
The front mounting tab bolt is spot welded in place. I see no reason you couldn't cut the spot weld and make the hole fit the 195 mount.
At the rear, the mount may be in the wrong position. I don't know for sure on this.
Here is a pic of the spring that holds them in place:
  • Utah Smitty and Bmerf have said thanks
#17 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 23, 2012 - 01:57 AM
Thank-you Russ and Kenny,
I now have a better idea as to how the panels mount. Can’t wait until they get here. I have the stud thing in front as seen in Russ’s first picture, should fit the hole in the front of the new panels. The back is probably in the wrong location, My idea was to hopefully move the rear 165 mount to the correct location or fabricate a new one, but did not have any idea as to what they looked like or where they mounted.
Russ the left 165 panel doesn’t have the cut out for the steering gear as seen in your last photo, it is identical to the right in appearance. Looks like a simple lazy “L” cut for clearance. Could you tell me if your panel is simply cut and left with a flat straight edge or is the edge rolled over in this location?
BTW invisible panels don’t hold paint very well.
Thanks again,
Brian
  • Russ said thank you
#18 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 23, 2012 - 07:41 PM
The edge is flat on mine,, hahaha an maybe ya should try to put primmer paint on then put the reg paint on the invisible pannels,,,, lol,, That mite help but I not going to promise,,,,lol, Good Luck I will go out an get more pic of the cut out side pannel for ya
Edited by Russ, July 23, 2012 - 07:54 PM.
  • Bmerf said thank you
#19 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 23, 2012 - 07:57 PM
Side pannel of the left side for FORD 195
  • KennyP and Bmerf have said thanks
#20 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 23, 2012 - 08:04 PM
This is the inside of the right side pannel can match up with what kenny's pic to see if it will fit,,
#21 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 23, 2012 - 08:07 PM
Sure looks like ya will have to redo the brace from the 165 to 195
#22 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted July 23, 2012 - 08:29 PM
That rear bracket will have to move. Russ, could you get a measurement from the top down to the bracket (not the locater)? Also one from the rear to the center line of it? That would get him close to where it goes.
Thanks for helping, Russ. I hope we can find your PTO soon!
One other thing, Russ get a measurement from top to bottom & front to back (at the point). I'll see about the same ones myself tomorrow! Just to make sure they are the same size!
#23 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 23, 2012 - 10:03 PM
Yea Kenny I will get em tomorro while its day light,, Pic comes out better that way,,
#24 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted July 25, 2012 - 05:44 AM
Well, life got in the way and I forgot to get the measurements yesterday. Will do as soon as it is light enough today!
#25 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted July 25, 2012 - 07:24 AM
I went out and measured the RH side. It is 34-7/8"+/- long at the point to the front. The front end is 18-3/4" tall, back is 20" tall.
#26 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 25, 2012 - 02:27 PM
Thank-you Kenny and Russ,
The pictures should prove to be a tremendous help. Panels came in, look like they will fit with the moving of the mount. No time right now to mess with them. Will see what the weekend brings. And get pictures. Thanks again.
Edited by Bmerf, July 25, 2012 - 02:28 PM.
#27 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted July 25, 2012 - 04:54 PM
Glad we could help out! Who knows when you might help someone else along the way! Just pass it along!
#28 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 29, 2012 - 10:03 AM
It mows, well sort of. The brand new belt that had laid out on the machine in the weather for fifteen years was only good for about 1 acre. But it proved that the rewired clutch was up to the task. It did a pretty good job considering the lack of blade sharpness.
Next up, get them hood sides mounted.
#29 KennyP ONLINE
  • 40,124 Thanks
  • 46,764 posts
Posted July 29, 2012 - 10:22 AM
Glad the belt lasted a while. At least you know the clutch is up to the task. Have you got the side panels, or are they still out sightseeing like my rollers?
#30 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted July 29, 2012 - 09:39 PM
Hey glad its working out for ya,,
