Road Trip For Bush Hog Parts!
108 replies to this topic
#91 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted July 29, 2012 - 03:34 PM
Glad to hear it runs. Also glad you got a little GT time. You were due for that!
  • olcowhand said thank you
#92 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted July 29, 2012 - 03:57 PM
The carb on the engine had a mounting ear broken off, but I had an old carb body in good shape, just bad dirty. Got both carbs mostly apart & soaking. Will be able to make one good carb from the 2. As soon as I get a carb back on the engine, I'll get some video. Right now it's kinda hard to pull the rope, have the carb spray ready, and hold a camera at the same time! :smilewink:
  • caseguy, Texas Deere and Horse and IamSherwood have said thanks
#93 IamSherwood OFFLINE
  • 8,395 Thanks
Posted July 29, 2012 - 06:03 PM
That's great, that the engine is in good shape. That means, that you should
have this girl on her feet, a whole lot sooner. :thumbs:
#94 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted July 29, 2012 - 06:32 PM
It will certainly help a lot Will. The transaxle has like new gear oil in it, and no leaks at all. So I also think I can avoid any transaxle work. These two major items in good working order means almost zero mechanical work, other than what's involved cosmetically. I would rather strip & repaint each piece as I go, and it will be some time before I can take on such a project. What I'd like to do first is to strip the frame & all the large pieces in my e-tank before wintertime, shoot them with primer, then set them back for when I can get into it serious like.
#95 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted July 29, 2012 - 06:41 PM
Sounds like a good plan, Daniel! Ought to make things go a bit quicker when you do get serious with it.
#96 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted July 30, 2012 - 08:44 PM
This is the engine off the Bush Hog D4-10 I bought in pieces from Bush Hog Corporation. Carb is still not correct, as you can see the choke butterfly is almost completely closed. I think for now I may borrow the carb off my "Ugly D4-10" to further check the engine performance.
But she runs & NO knocks, and NO smoke at all! Great engine, just needs more tuneup work. Please look away from the mess around my shop door. Been a wild spring/summer & I never get things done like I should.
#97 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,380 Thanks
  • 5,611 posts
Posted July 30, 2012 - 08:47 PM
Good Stuff
#98 caseguy OFFLINE
  • 1,629 Thanks
Posted July 30, 2012 - 08:52 PM
That's great news Dan! Some guys have all the luck! I'm glad that it's a good strong runner.
#99 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted August 04, 2012 - 03:07 PM
Borrowed the carb off the rusty D4-10 today, and this engine runs sweet! I also took the points apart & cleaned them up & adjusted. No difference until I swapped carbs. I have a bid on one that's on ebay, as I have no more carbs to rebuild. Something wrong with this one that I can't find. I want the rusty D4-10 back running too.
#100 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted August 04, 2012 - 05:41 PM
I went to remove the pipe from the 45 street elbow in the engine, and I seen right off the elbow was not solid in the engine threads. Got it out, and found I'll need to clean the threads in the block before putting in a new elbow. May see if the local hardware store has a tap to loan me to chase the NPT threads. If not, I'll get the dremel out.
#101 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted August 04, 2012 - 07:16 PM
Found pipe fittings I needed, so I just notched a pipe at several spots so it would chase the threads in the block. Worked great, so I now have the "pepper pot" muffler on. I also took off the back half of the bell housing & greased the throwout bearings & the driveshaft bearing with a grease needle. Once back together I pulled on the clutch lever & the clutch disengaged fine. Many times the clutch disc will freeze to the pressure plate, so i wanted to check that now. Video of her running better coming.
#102 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted August 04, 2012 - 07:33 PM
Glad you got the threads cleaned. Sounds like you're on a roll here.
#103 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted August 04, 2012 - 07:37 PM
Runs pretty decent. I didn't tighten the throttle plate nut enough, so the throttle eases back down on me during the video. Just hung a D4-10 fuel tank from my garage door to run it. This engine is pretty much ready for cosmetic work. I'm bidding on better engine tin, a carb, and complete air filter for it now. Borrowed the air filter along with the carb from the other tractor.
#104 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted August 04, 2012 - 07:51 PM
Sounds good! I like your IV for it. Don't have to worry about flow that way!
#105 Texas Deere and Horse OFFLINE
  • 14,866 Thanks
  • 15,512 posts
Posted August 05, 2012 - 01:01 PM
Daniel, That engine sounds sweet. Glad you had some extra parts to get it running for the test stand. It won't be long before you have running around the barn yard. way to go my Friend !! :thumbs:
