John Deere 165 Hydro Frozen Wheel
6 replies to this topic
#1 bassman OFFLINE
bassman
  • 2 posts
Posted July 17, 2012 - 02:53 PM
I've got a JD 165 Hydro and I'm trying to get the right rear wheel off of the axle. She seems to be stuck (i.e. rusted) pretty good. I've been pouring the PB Blaster to it every few days, but that hasn't freed anything up yet. Anyone have any suggestions as to what I can do with out damaging the rearend, to get that stubborn rim off? Thanks in advance.
  • 14,889 Thanks
  • 15,514 posts
Posted July 17, 2012 - 02:56 PM
First off, Welcome to GTtalk, glad you found us.
Does the 165 rim mount on a hub or straight on the axle shaft?
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 17, 2012 - 07:12 PM
I believe the 165 has a keyed shaft that fits directly into the rim. If the tractor is still moving I'd run it around the yard stopping and starting a few times. The torque applied to the axle while driving might help the penetrating oil do it's job. Take your time and don't rush it. I'd keep soaking it every day for a week if you have the time. Heat is another good thing but you don't want to ruin the seals or the tire. Try a heat gun to carefully heat the rim. A large puller might encourage it to come off as well.
#4 bassman OFFLINE
bassman
  • 2 posts
Posted July 17, 2012 - 07:58 PM
Well, you're right that the rim is keyed to the axle shaft. Its a woodruff key. This has been an ongoing issue over a few months. I drive it and keep squirting the penetrating oil whenever possible. If this thing were to free up by the fall, I would be happy. I need to get the rim off so I can work on the brake issue which is not functioning correctly.
Bill
  • 14,889 Thanks
  • 15,514 posts
Posted July 17, 2012 - 08:41 PM
You can also try putting some heat on the hub, just be careful not to heat the rim up enough to pop the tire, they will explode from too much pressure from the heat. Might remove valve core before applying heat.
  • Trav1s said thank you
#6 Trav1s ONLINE
Trav1s
  • 3,584 Thanks
  • 4,560 posts
Posted July 23, 2012 - 11:28 AM
My thoughts exactly!
#7 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 23, 2012 - 11:32 AM
Woodruff keys are not my favourite things. I find they often seem to be hard to remove. Some heat would be my next step as well. Good luck with it.
