Do Mower Blades Bend With Heat?
6 replies to this topic
#1 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted July 17, 2012 - 10:57 AM
I want to make a set of hitch block adapters for the '71 so I can use front attachments from the '75 on it. I have most of the material on hand already. Except for material to make the mount for the front blocks. I was looking at my steel and found that the only flat steal I have are old mower blades. And go figure, PK blades would work perfect! So, if I got them cherry red do you think they would bend? I don't really think so but I thought I would check with some people who may have tried before. They seem kinda brittle to me.
I attached some pics and a PDF file so you can get a better understanding of them if you are not familiar with Power Kings. The actual pics belong to ariensman2. You can see on the front blocks they used C channel, I don't have any channel that size, that is why I want to bend the blades.
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,965 Thanks
  • 9,612 posts
Posted July 17, 2012 - 11:39 AM
If you get them cherry red, the brittle will go out of them. Give it a try and don't force it. If they are hot enough, they will bend easy.
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted July 17, 2012 - 12:25 PM
Big problem with mower blades is that they are almost impossible to drill a hole through the without specialized bits. But as LilysDad said they will bend easily with heat. Put one in a vise hot and you can even get a 90* angle with a hammer.
Good luck,
Bill
  • 14,730 Thanks
  • 15,470 posts
Posted July 17, 2012 - 12:58 PM
you need to get them as hot as possible, almost white. The hotter they are, the easier they will bend, and don't quench them in water when your done, they will become even more brittle.
#5 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted July 17, 2012 - 11:08 PM
If you heat them and let them air cool, it takes the temper out of them and you can drill them ok afterwards. Used to do the same thing with bed rails.
Or you can do like a friend of mine used to do and "drill" holes in them with a gun!!! Just a little harder to be precise with hole placement......
#6 HowardsMF155 OFFLINE
  • 2,836 Thanks
  • 2,977 posts
Posted July 17, 2012 - 11:19 PM
Works well with .44 holes or perhaps .45. But dang it, sometimes you just need a .75 hole, and what pawn shop has THAT ammo in stock??
#7 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted July 17, 2012 - 11:28 PM
Thanks for all the advice! If it weren't for you guys I would have made several mistakes. As you can see in the pics, they used C channel for the front blocks, unforunetly I don't have any.
Howard, I know somebody who can get you some stuff. PM me if you are interested...
