Need Help With 88 Thru 92 Dodge Cummins Wiring
11 replies to this topic
#1 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted July 16, 2012 - 04:21 PM
This is the wiring diagram for a 89 thru 92 Dodge Cummins manifold heater electronic control module.
This is a new electronic control module made by Cummins.
The wire colors on this ECM are not the same as my Dodge diagram.
This ECM has a 6-wire plug marked A thru F from left to right as it is shown in the photo with the clip facing up and the two wire plug is marked A - B.
Colors are :
( 6-wire )
A - blue
B - red
C - orange
D - purple
E - green
F - brown
( 2-wire )
A-black
B-yellow
Do you have a 89 thru 92 Dodge Cummins ?
If so .. can you tell me what color wire is going into which position on the OEM plug so I can then match them up to the wires on my plug ?
I sure would appreciate any help I can get.
A photo of the factory plug and wires would be really great.
My email is: jdcrawler@yahoo.com
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted July 16, 2012 - 06:16 PM
I found this website with 4 pdf's of cummins engines, but am unsure if any are helpful.
http://dodgeram.org/.../ECM/index.html
  • jdcrawler said thank you
#3 Alc ONLINE
  • 7,221 Thanks
  • 7,576 posts
Posted July 17, 2012 - 06:36 AM
Does this help ? Al
#4 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted July 17, 2012 - 07:21 AM
Does this help ? Al
Thank you for the diagram, Al
The ECM on that diagram has 10 wires and my ECM only has 8 wires ?
#5 Alc ONLINE
  • 7,221 Thanks
  • 7,576 posts
Posted July 17, 2012 - 08:49 AM
Ray that was for 1990 single board engine controller , I'll see if I can find maybe another year which might have the correct# of wires on the controller , Al
#6 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted July 17, 2012 - 09:12 AM
Thanks, Al
I was told that this was for a 89 - 92 Dodge Cummins but I'm thinking that it may not be for a Dodge at al and might be for tractor, boat or something else.
#7 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted July 17, 2012 - 10:20 AM
I will give my one friend a call. He had a 91 Dodge with a Cummins in it. I am not sure if he still has it though. If he does I will go over and get some pics.
#8 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted July 17, 2012 - 10:25 AM
Ray, another good place to check while I am thinking of it is the TDR. Turbo diesel registry. I don't know if you are a member there or not, I used to be a member there back when I had my Dodge's. Wish I still had them but life happens and I had to sell them.
#9 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 17, 2012 - 10:26 AM
JD, were do they hide that module? Can not locate mine.
#10 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted July 17, 2012 - 10:33 AM
I went to our local Dodge dealer this morning and it turns out that this is not a ECM for the Dodge trucks.
The 89 & 90 Dodge truck used a ECM like this but it has 10-wires and this unit only has 8-wires.
#11 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted July 17, 2012 - 10:34 AM
.... GOOD NEWS .... I found a wiring diagram and operating instructions for this ECM.
....Thank you all for your help in trying to figure this problem out. .....
This unit was part of a kit put out by Cummins to put the cold start system on 4-cylinder and 6-cylinder industrial engines.
Edited by jdcrawler, July 17, 2012 - 10:39 AM.
#12 bh115577 OFFLINE
bh115577
  • 443 Thanks
  • 240 posts
Posted July 17, 2012 - 11:35 AM
If you ever need Mopar or Cummins info this is the best place I've found. Very knowledgeable people and always willing to help out.
http://articles.mopar1973man.com/
