Big Ten Won't Start Hot
9 replies to this topic
#1 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted July 16, 2012 - 09:52 AM
I have a Big Ten that won't start for anything after its run for a while. It looks to me like it is vapor locking. I would just put clothes pins on the line to absorb the heat, but it is a rubber flexi hose. Any advise is appreciated, do I need to run the fuel line a different way, or just get a new fuel line made of different material? Thanks!
#2 Ryan313 OFFLINE
  • 3,242 Thanks
  • 5,159 posts
Posted July 16, 2012 - 10:15 AM
If it is run the way it would have been run, from the factory. It is most likely not the problem. I would take the carb off and clean it really good. Replace the filter and check to make sure all of your lines are clear.
  • 14,594 Thanks
  • 15,426 posts
Posted July 16, 2012 - 10:30 AM
Next time it does this, check the coil for spark. Old coils have a habit of breaking down when they are hot and not making spark.
#4 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 16, 2012 - 10:46 AM
took the words right out of my mouth , i have a kohler the same way. wont run when its hot. let sit over nite and she will fire right up.
#5 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted July 16, 2012 - 10:51 AM
I'll try looking at the coil, I just cleaned the carburetor and bought all new gaskets for it, so that must be it.
#6 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 16, 2012 - 11:03 AM
run it till it dies then check for spark.
#7 JDBrian OFFLINE
  • 9,596 Thanks
Posted July 16, 2012 - 11:52 AM
If the engine is running hot it will increase the tendency to vapour lock. Make sure your cooling fins and flywheel cover are clean.
#8 Wheel Horse Kid OFFLINE
Wheel Horse Kid
    Certified Wheel Horse Nut
  • 213 Thanks
  • 817 posts
Posted July 16, 2012 - 12:07 PM
I agree with the others to check the coil. I had an 8hp B & S motor that would quit when the it got hot. It ended up being the coil. Hope you are able to get it fixed soon!
#9 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted July 16, 2012 - 12:11 PM
It will run as long as it has gas, it just won't crank up once I turn it off. Does anyone have a coil they could recommend to me? I am going to replace it and see how that does.
#10 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted July 17, 2012 - 06:11 PM
hate to say this but it could be compression ,check it cold and then check it hot or when it stops running . John 3:5
