Update On The '73 140 H3
30 replies to this topic
#16 MH81 OFFLINE
Posted July 19, 2012 - 09:54 PM
Dane, I Wish I knew more about the JD Decks so I could Help...
There is a thread about rebuilding spindles here, will try to find it. The reason I mention it, is if you use heat, you're probably going to need to replace the lower bearings unless you get lucky.
#17 MH81 OFFLINE
Posted July 19, 2012 - 09:55 PM
Here it is. The deck is off a 110, but I'm hopeful most of the principles apply
http://gardentractor...ld/#entry189144
  • Dane in PA said thank you
#18 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted July 19, 2012 - 10:41 PM
I haven't had the ones on the 140 apart but I believe it is the same as the 212 and on that deck the square part of the carriage bolt was rusted and rounded off as soon as I spun the nut. So I ended up using a air die grinder with a cut off disc to cut the nut off and will replace them with new bolts when I get ready to reassemble it.
What do you mean by get the hydro ports on the back? Mine are there and work.
Bill
Edited by GTTinkerer, July 19, 2012 - 10:42 PM.
#19 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 19, 2012 - 10:50 PM
Bill
For the tiller and 3-pt the ports are moved to the back I believe. I have both sets of mine up front, and the ones on the rear for the deck lift.
#20 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 19, 2012 - 10:53 PM
I need to get the blades off the spindles. Are they reverse thread? Normal? Do I need to apply heat to break something loose? Thanks for the link, as that will come in handy if I rebuild these spindles.
Edited by DaneinPA, July 19, 2012 - 10:54 PM.
#21 k91 OFFLINE
k91
  • 3 Thanks
  • 5 posts
Posted July 20, 2012 - 11:06 AM
Dane they are regular thread. You might need some force to break them loose. Heat will help. Sometimes an impact gun cannot even break them loose. If this is the case get a large breaker bar and put a pipe on the end of it. Use a big piece of wood like a stop to keep the blade from turning. You'll get them. Good luck :thumbs:
#22 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,498 posts
Posted July 20, 2012 - 01:16 PM
Try an impact wrench.
#23 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted July 20, 2012 - 02:20 PM
I thought you were talking about the bolts holding the spindle to the deck.
Bill
#24 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 20, 2012 - 07:15 PM
I tried a lug driver to no avail, and I can get just about anything with it. I think I am going to remove the deck, and let it sit for a while with PB on the bolts, then try later.
#25 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 20, 2012 - 11:08 PM
Might have my Pap's Harley sold for him tomorrow, and he said I get 20%, and if I do I am putting in an order for a Buford Bucket.
#26 MH81 OFFLINE
Posted July 30, 2012 - 06:16 AM
Dane, I missed this post, how did you make out on the bucket?
#27 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted July 30, 2012 - 08:24 AM
Here is a picture that shows how to ad tees in and where to put ports out the back. ImageUploadedByTapatalk1343654581.587527.jpg ImageUploadedByTapatalk1343654610.935588.jpg ImageUploadedByTapatalk1343654641.154696.jpg ImageUploadedByTapatalk1343654673.361083.jpg
Hope this helps.
#28 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 30, 2012 - 08:28 AM
Still working on it!
Hope this helps.
Thanks!
#29 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted July 30, 2012 - 10:54 AM
Dane. Heat the bolt up but not red hot. Touch it with a candle for a while to get the wax down in the seized section. That bolt should come out with a impact after that. Just don't let everything cool off..
#30 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 30, 2012 - 11:35 AM
Will have to try that.
