Ff18 + Other Harrisonville Mo
This topic has been archived. This means that you cannot reply to this topic.
44 replies to this topic
#1 MH81 OFFLINE
Posted July 15, 2012 - 08:09 PM
http://kansascity.cr...3140583549.html
#2 KennyP ONLINE
  • 37,455 Thanks
  • 45,480 posts
Posted July 16, 2012 - 07:57 AM
Wish I had a few extra dollars right now. Love to have that FF.
#3 Wheel Horse Kid OFFLINE
Wheel Horse Kid
    Certified Wheel Horse Nut
  • 213 Thanks
  • 817 posts
Posted July 16, 2012 - 08:44 AM
Wonder why the ad got flagged??
#4 MH81 OFFLINE
Posted July 18, 2012 - 06:43 AM
Rat, :welcome: to GTTalk.
Sounds like you have a project on your hands, but at least you have an FF series.
I would contact our site sponsors, if anyone can help here, it's probably one of them.
Their contact forums are here: http://gardentractor...-site-sponsors/
#5 KennyP ONLINE
  • 37,455 Thanks
  • 45,480 posts
Posted July 18, 2012 - 06:58 AM
Welcome aboard, rat88! Glad you grabbed that FF. Have you found the Sears model # for this? Should be on a plate, possibly on the rear just below the fuel tank. It will be possibly a 917.?????? number. The GTV's were very similar, may use the same steering.
I just repainted my GTV and looked over the steering real close. Maybe I can help you out on what will fit.
#6 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted July 18, 2012 - 07:18 AM
I have not had any time to do any serious tire kicking on it yet. just unloaded it yesterday and headed back to work.
185 hrs in 15 days. Im gonna need some reboot time before I get into this tractor very far
#7 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted July 18, 2012 - 11:54 AM
I have managed to get part numbers but have not found any good pics, just an old crappy hard to read parts list.
shaft assm. 677H540 (not available)
pinion 3945J (AYP $52 )
Not sure if pinion is actually in stock. I have ordered ford part from New Holland that appeared to be in stock, only to get a call later stating that they were cancelling the order... parts are not available.
#8 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted July 20, 2012 - 09:19 AM
If you still need the parts shoot me a pm. I have a ff/18 that is getting ready to be parted out.
#9 KennyP OFFLINE
  • 37,455 Thanks
  • 45,480 posts
Posted July 20, 2012 - 09:44 AM
Wish I could afford the rear out of that machine, Bob. I'd make my GTV/16 into an FF.
#10 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted October 12, 2012 - 01:56 PM
I have fixed the steering on this and got it running good. Still need to work on the hydraulic lift, the lever moves but not easy. Lift wont move. It takes a while before the hydro starts working after it sits over night, 1 minute or more. It sounds like it is getting air in the system from some where. Is this a sign of a weak pump or just an old dry O ring?
It seems to move good once it gets right. I have not tried to do any hard pulls yet, just a trailer toter right now. I plan on building a snow blade for it, but I am not sure how good the hydro will work when it gets cold.
#11 UncleWillie OFFLINE
  • 15,527 Thanks
  • 8,706 posts
Posted October 12, 2012 - 06:10 PM
I hate you. :D I want an FF so bad I can't stand it. Get some pics up.
#12 MH81 ONLINE
Posted October 12, 2012 - 06:19 PM
Rat, did you change the oil & filter?
#13 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted October 13, 2012 - 02:42 AM
Not yet. still kicking the tires, It dont pee on the floor, so it isnt an external leak. I am thinking it's due for an overhaul. The two for one deal dont look so good now. The gilson is gonna need some work too.The price was right , so what the hell. Gonna need some thing to do this winter.
Doing a quicky/ cheapy paint job on my sons truck this weekend. $500 farm truck with a $50 paint job, Not going for " show truck" just better than it was. Flat black and barn yard patches on the rust holes
The GT's are on the back burner for a few weeks.
Edited by MH81, October 13, 2012 - 05:22 AM.
#14 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted October 13, 2012 - 08:50 AM
If that rig has the Eaton 11 hydro I would make sure its full and has the correct filter . Use a quality hydraulic oil / tractor transmission fluid like hy-trans. If this doesn't cure it, it may have an issue with the charge pump or hydraulic valve for the lift. If it has issues with valves internally like the cushion or relief valves this is an involved repair.
#15 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted October 24, 2012 - 06:33 PM
The hydro is working alot better now. I think it just had arthritis from sitting so long. I got the lift working, just need to build the 3 point set up. I just missed a set on fleebay by a month. Snagged the pic. They dont look too complicated, no fish eyes in them. That might make it hard to hook up equipment and feel sloppy.
