Did Cub Cadet make a gear drive brother to my 147?
16 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted July 12, 2010 - 10:45 AM
I have been debating what I want to do for a pulling tractor and I really like the looks of my 147 but would like to have it gear drive. I would rather not molest my 147 to make it gear drive either. So my question is did Cub make another narrow frame that looks like my 147 with the 14 or 16 hp Kohler in gear drive?
#2 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted July 12, 2010 - 10:46 AM
I forgot to add that the other thing I thought about doing is I really like the Cub 100 with the round fenders and putting a 14hp Kohler in it.
#3 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 12, 2010 - 11:44 AM
Can not answer your question.The 100 series w/Std. trans. were tough little devils to out pull but did get it done on occasions w/ our MF 10.
Hydro does consume some of your power before it gets to the ground and standard is all about gear ratio and tire size to get it to the ground.
#4 olcowhand ONLINE
  • 42,896 Thanks
  • 31,938 posts
Posted July 12, 2010 - 11:51 AM
Odd numbers are hydro, even are gears. For most models there is a gear drive brother, but I can't find anything to match with your tractor.
#5 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted July 12, 2010 - 11:59 AM
I think I might have to just do a 100 and shoehorn a 14hp Kohler in it. I have also thought about the idea of turning the MF12G I have into a puller.
#6 mjodrey OFFLINE
Posted July 12, 2010 - 12:47 PM
It doesn't appear that IH built a geared "brother" for your 147,or at least I can't find anything.
#7 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 12, 2010 - 12:56 PM
We had to increase the spring tension on the Vari-Drive a bit and then it would hold what the engine throw at it. Also if I remember correctly the 10 and 12s had pulley on the drive axle that you could adjust the width to match gear ratio to power. Been a while since I saw one.
#8 ACecil OFFLINE
ACecil
  • 460 Thanks
  • 339 posts
Posted July 12, 2010 - 02:50 PM
IH made the 106 and 126. The 106 has a 10 hp Kohler, while the 126 has the 12 hp Kohler. They are in the same series, as your 147. You could get either of those models and add a 14 hp engine. They look just like the 147.
#9 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted July 12, 2010 - 02:59 PM
The thing I like about the 147 is how the frame is notched out from the factory to fit the 14hp in the narrow frame. I really like the looks of the original and the 100 so I may just look for one of them. I only plan on ever pulling in the stock class and everything will bolt on to factory bolts so it won't harm the tractor for value.
I may eventually get into the more modified pulling but my pocket book isn't that deep right now nor will it probably ever be LOL.
#10 studeman68 OFFLINE
studeman68
  • 5 posts
Posted August 14, 2010 - 09:30 AM
126 is as close as you will get, both are narrow framed and were built from 1969-1971
#11 pattonacres OFFLINE
pattonacres
  • 105 Thanks
  • 46 posts
Posted August 31, 2010 - 08:32 PM
if you want to add a 14 hp you would need a 147 notched frame or use a 12 hp flywheel on the 14 to fit it. I have a 100 with a 14 and 12 hp flywheel. lots of power
#12 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted September 10, 2010 - 01:42 PM
I would love a 100 with a 14 or 16 Kohler on it. You gotta post some pics of your 100 Rich. :D
#13 Grumpy ONLINE
Grumpy
  • 747 Thanks
  • 623 posts
Posted September 10, 2010 - 03:13 PM
I have a cub 100 strong 12. 18 hp cam and a 16 hp carb. It pulls 12 in. plow with ease.
#14 Brent OFFLINE
Brent
  • 5 Thanks
  • 18 posts
Posted October 09, 2010 - 06:34 PM
I can't see all the features of your tractor, but my 102 looks similar. It had the original fenders removed and the fenders off of a 1450 installed.HPIM2583.jpg
#15 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted October 09, 2010 - 06:48 PM
I like the way that looks with the same rear fenders as my 147. That is what I didn't like about the 125 I had was the fenders. I love the round fenders on the original and the 100 though.
