Tire Question
5 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 14, 2012 - 04:30 PM
my ford has 22x9.00-12 on the back. i can get a pair of 23x10.5-12 ags for about 125.00
would i need to do anything special to the tractor so i can still use it to mow once i get it running?
#2 KennyP ONLINE
  • 40,034 Thanks
  • 46,727 posts
Posted July 14, 2012 - 04:36 PM
Maybe check the deck for level. Are there any adjustments to level it?
#3 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 14, 2012 - 05:13 PM
its a floating deck. its either all the way up or all the was down. i should be able to adjust with the chains if needed.
#4 MH81 OFFLINE
Posted July 14, 2012 - 06:42 PM
I would think you'd be just fine. Like Kenny said, maybe a little deck adjustment, but other than that... the little bit of difference isn't much. You have more than 3/4" between your current tires and the fenders?
#5 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 14, 2012 - 06:55 PM
i dont know about 3/4" but i do have 2" at top of tire
#6 JDBrian OFFLINE
  • 9,626 Thanks
  • 14,151 posts
Posted July 14, 2012 - 07:01 PM
One other consideration is the rim width. A 9" wide tire will typically call for a 7" rim while a 10.5" will call for a 8.5" rim.
