New To Me Case 195
82 replies to this topic
#31 MH81 OFFLINE
Posted July 14, 2012 - 09:34 PM
Caseguy had to replace those lines on his 2-2-something. Listening to him tell the story, I couldn't help but smile... Not at his misfortune, but at the fact that I've been that frustrated before.
From what I understand, get the Original hose. There is one fitting in there that is some kinda over engineered wonder (right angles or something) and a straight away won't work.
I'll let him tell the story, just don't let him see you smile... :)
#32 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 14, 2012 - 09:41 PM
I hope he comes by soon then! I want to hear this! It does not look like it is a special line. It has some fittings on the cylinder end, one of them is a 90 degree elbow. I don't remember what is on the other side.
#33 MH81 OFFLINE
Posted July 14, 2012 - 09:44 PM
Maybe it was a different hose. His went back to the drive motor.
#34 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 14, 2012 - 10:17 PM
Yes, that is a different hose. I would still like to hear the story though!
#35 KennyP ONLINE
  • 38,278 Thanks
  • 45,883 posts
Posted July 15, 2012 - 07:07 AM
Ouch on that axle! Glad you were able to get it out. Hope a replacement isn't too hard to find, Ryan! Good luck!
#36 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 15, 2012 - 09:11 AM
I am hoping I can find an axle without problems. The broken one is a little longer then the other side they are not interchangeable either.
I finally got the tractor in the registry!
#37 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted July 15, 2012 - 09:25 AM
Glad to see you got it apart, and your doing a great job. Ryan, I knew you were young, but I just realized your 15, and I have to say, you have got serious skills for being only 15. :thumbs:
Matt
#38 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 15, 2012 - 10:22 AM
Thanks, Matt!
I just wire brushed all the contact surfaces. When the PO took anything apart he put silicone in it to seal it. I wanted to get all of that dried silicon off, I will make new gaskets.
#39 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 15, 2012 - 11:21 AM
I hope a new axle is easy to find for that. You are making serious progress on it. Did you have to hack saw that axle off. If so it must have been an awkward job.
#40 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 15, 2012 - 11:28 AM
No, I used a small 4 1/2 inch grinder. It worked pretty good! I just held the grinder still and spun the hub around and it cut it off.
#41 Fabman OFFLINE
Fabman
  • 257 Thanks
  • 374 posts
Posted July 15, 2012 - 12:02 PM
Nice Case you got there Ryan. Your doing great, hope you don't have a hard time finding your axel. That deck looks to be repairable to me. I'v done alot worse looking ones than that. Got faith in ya young-in. Randy G.
#42 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 15, 2012 - 08:45 PM
I got brake cleaner today. I have a roll of gasket paper, I am not sure if it is too thick though. If it is thin enough then I can start to reassemble tomorrow. If it is too thick it will have to wait a few days
#43 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 16, 2012 - 01:13 PM
The gasket paper I have is thinner then I thought. I was able to get everything cleaned down and I assembled as much as I could without the other axle.
Edited by Ryan313, July 19, 2012 - 01:53 PM.
#44 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 16, 2012 - 01:42 PM
The other day I was looking at the hydraulic system and couldn't find the reservoir. After I started with the trans-axle I noticed the case was the reservoir. Does anybody know how much fluid I should have in the trans-axle case?
  • Utah Smitty said thank you
#45 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 19, 2012 - 10:12 PM
A good thread Ryan. Unfortunately only the last picture can be seen--at least on my computer. I have a Case 195 with a sickle bar mower that I need to get running again. The engine had a slight knock which I got corrected, now I need to put it aback together--hope I can find all the parts.
If you can, try and repost your pictures in one post--I'd like to look at them.
Utah Smitty
