43c Center Blade For Jd 110
43c center blade
6 replies to this topic
#1 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted July 11, 2012 - 09:53 PM
I'm looking for a Center Blade for my 43C JD 110. Any idea where I might find one and what I can expect to pay? Thanks in advance for your help.
Also, any thoughts on if this is the best solution for grading my long dirt driveway? I've got pot holes and am hoping this type of rig might allow me to fill the holes while smoothing out the surface. Thanks.
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 12, 2012 - 05:03 AM
It's best to scarify the driveway first then grade it. If you just fill over the potholes they will reappear quickly. I would look into a box blade as an alternative or even some sort of a cultivator or home made scarifier to use before using the centre blade.
#3 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted July 12, 2012 - 10:20 AM
There was one on ebay. It can still be on there. The buy now was list at $400.
#4 ckjakline ONLINE
ckjakline
  • 1,144 Thanks
  • 1,135 posts
Posted July 12, 2012 - 03:32 PM
The center blades are pretty salty from what i've seen. $400-$450.
#5 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted July 12, 2012 - 04:32 PM
If you have the tools, make one! I made this one from a newer JD front blade:
The rear brackets stay on the tractor, two pins there & the mower deck lift links to hook it on.
I have since remodeled the mounting frame to fit my 314. ~~ Lowell
#6 Moosetales OFFLINE
Moosetales
  • 1,089 Thanks
  • 1,284 posts
Posted July 12, 2012 - 10:18 PM
Thanks guys. I will have to think a bit on what my next move is. I currently use an I beam that my dad fixed up for me and I drag that up and down the lane until I've broken through the top crust and then I can start moving some dirt. The problem with the beam is that is follows the conture of the dips and holes sometimes so I thought a fixed blade might work better. Thanks again for all the great feedback.
#7 jdnut OFFLINE
jdnut
  • 6 Thanks
  • 20 posts
Posted August 08, 2012 - 08:04 AM
I seen then for sale on the WFM web site!
