Tire Pictures From My Bush Hog Hd-12 For Scott
25 replies to this topic
#16 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted November 29, 2012 - 09:16 PM
I got the rear rims (JD implement rims) that are 6 lug, so I am good to go. But the front tires are currently 12" rims....I know that has got to drop down in size, since the jd rear rims and tires will be smaller
#17 olcowhand ONLINE
  • 38,021 Thanks
  • 30,443 posts
Posted November 29, 2012 - 09:18 PM
Oh, I forgot you had rear rims, and thought you were speaking of fronts. Sorry bout that Scott!
#18 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted November 29, 2012 - 10:05 PM
Yes its the fronts I got to figure out at this point. The rear tires that are on it are 27" and the Goodyear Terra's will be 26".
Pretty sure they dropped down from a 12" to probably a 8" rim....but want to make sure and also what was the tire diameter and width....I may change it a little but at least wanted to know the "true size" just incase I did stay "original".
Ya think a set of those 26-12 would work/look good on a D4-10?
#19 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted November 29, 2012 - 10:27 PM
What do you need for the front? Would the 8s off a case 220 work?
#20 olcowhand ONLINE
  • 38,021 Thanks
  • 30,443 posts
Posted November 30, 2012 - 08:50 AM
Not sure about that one. Might look out of scale on a D4-10. 23x10.50-12 ags look about right.
  • sacsr said thank you
#21 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted December 03, 2012 - 09:24 PM
Not sure, once I find out the correct tire and rim size, the answer may be yes.
#22 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted August 10, 2013 - 07:24 PM
Picked up a Set of Carlisle Turf Saver 20x8x10 this week. I am going to use them on the front of my HD -12 with the Goodyear Terra ags 26-12-12's on the rear. My local store has a 10-5 rims for $25.... I would like the tires to be a little more round than square if that is possible. Will this rim be a good candidate for this tire or do I need a wider rim? (These 20-8-10 tires have been hard to find in a pattern I liked.)
  • olcowhand said thank you
#23 olcowhand ONLINE
  • 38,021 Thanks
  • 30,443 posts
Posted August 10, 2013 - 07:37 PM
I think they would work fine.  It would pull the beads in enough to add more round to the tire shape.
#24 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted August 12, 2013 - 08:32 PM
Well the rims were 10-6 and are not off set.......I don't think this is going to work as it is....see the pictures....to outside of rim is slightly more than 7".  Anyone know of an offset 10" rim?? Going to do some more research tonight.
#25 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,403 Thanks
  • 3,342 posts
Posted August 14, 2013 - 08:48 PM
Pulled the HD-12 tires off tonight and put them back on the "narrow" set up....really like the look at lot more than the wide....but when I was taking off the left rear tire (sitting on tractor), I noticed the hub was wobbling a little. Well not sure if this is designed this way or not (will check my other HD-12 to decide) but the key way on the hub is about 3 keyways wide on the wheel side and only 1 keyway wide on the axle housing side??? That is the give the hub rotates on the axle till it hits the wall.
#26 olcowhand ONLINE
  • 38,021 Thanks
  • 30,443 posts
Posted August 14, 2013 - 09:40 PM
One of the hubs on one of my JB's was worn just like that, but also the keyway in the axle as well.  That is worn, not made that way.
