Tire Pictures From My Bush Hog Hd-12 For Scott
25 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted July 11, 2012 - 04:19 PM
Here are the pics I took of the ag tires on my HD-12 for Scott a while ago but I forgot to post them.
Sent from my Galaxy Nexus using Tapatalk 2
  • sacsr said thank you
#2 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted July 11, 2012 - 05:06 PM
Thanks George! So the rears have 12" rims.....5 or 6 lug?? What size are your fronts??
Reason I am asking is my rears are 15" rims and the fronts are 12" rims.
#3 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted July 11, 2012 - 05:30 PM
The rears are 6 lug I believe. They would be the same lug as yours. Not sure on the front size but I think they are 8".
#4 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted July 11, 2012 - 05:45 PM
I was assuming 6 lugs like mine but had to ask.......I am finding that used 6 lug 12" rims are not been as easy to find....i found some nice lugs locally but the rims were 5 lug 12" rims...... .......any other make have a 6 lug 12" rim?
Thanks
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 12, 2012 - 04:50 AM
JD 400 used 6 bolt rims but I'm not sure if the bolt pattern would be the same.
#6 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted July 12, 2012 - 09:10 AM
I was looking at EBAY and I think the Bolens HT20 and 1455 model rims are 6 bolt as well.......I have the ag tires so unless they are rims with ags....I need just the rims.
Edited by sacsr, July 12, 2012 - 09:19 AM.
#7 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted July 12, 2012 - 09:20 AM
You could always stay with the stock narrow tire setup but I know that you like the look of the ags and I am the same way. They just don't seem right with the skinnies on them.
#8 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted July 12, 2012 - 10:02 AM
Yes I like the AG look better..........with some more research looks like all the early large frame Bolens all have 6 bolt rear rims.....so maybe i can find a used set of them.
#9 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 12, 2012 - 01:31 PM
Scott, I'll have to check, but I think maybe ag implement rims are the same bolt pattern in 6 lug 15" rims. I'll go take a look in a while & check to be sure. If they are, then you can get rims at any ag parts supply, or at least at an implement dealer.
#10 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 12, 2012 - 01:42 PM
Yep, a perfect match! I checked my Allis 620 with 15" rims, the JBI with 12" rims, and my MF 1855 w/12" rims. ALL a match to ag implement bolt patterns. 3" between bolt centers, and a 4 1/2" center hole! No problem for you to find Scott!
#11 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted November 29, 2012 - 07:20 PM
Well sent money yesterday on my Goodyear Terra Ag tires. Will be glad when they arrive. Finally finding those has me back on getting the HD-12 up and going. George hate to bother you but I need the rim size and the tire sizes off your HD-12. The brochures and manuals only show the tire combination that I have with the 15" rears and the 12" front skinny tires .....not the 12" rear fat tires like you got! Which is pretty funny since the brochure has the picture of the HD-12 with the smaller fatter tires on it! Your help would be greatly appreciated!
#12 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted November 29, 2012 - 07:28 PM
George, while you're at it, check the offset on the rim center.
#13 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted November 29, 2012 - 07:57 PM
Forgot to clarify that I need the front tirs and rim size. Thanks Daniel, I do need the offset info to since I will looking for those as well......maybe I will get lucky and I can use the rims off on of the D4-10's! Thanks
#14 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted November 29, 2012 - 08:46 PM
D4-10 are 5 lug....aren't your HD hubs 6 lug?
#15 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted November 29, 2012 - 09:01 PM
Wheelhorse D series have 12 inch 6 lug rims. they also offered 15 inch 6 lug.
