Kohler K181 In My Original Causing Erratic Behavior
4 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted July 11, 2012 - 01:32 PM
I've been having troubles adjusting my originals governor correctly to get a good range of speed with the throttle. I've followed the kohler manual to the letter and am having trouble. It will speed up to about a high idle and them, with just a little more throttle, will speed away erratically. I'm usually pretty good with these so this has me frustrated. Any ideas?
#2 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted July 11, 2012 - 04:39 PM
I am going to take a guess and say that probably something inside the motor is broken. Maybe the weights on the gov. gear have let loose or maybe the actuator arm on the cross shaft.
#3 MH81 OFFLINE
Posted July 11, 2012 - 05:48 PM
I think Kelly nailed it. Sure sounds like the internals if nothing else has changed. All springs there and where they should be?
#4 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted July 11, 2012 - 06:48 PM
Check all the linkage for slack and wear. If something is sticking or has a lot of slop in it you can get some strange behaviour. I recently fixed up a 3.5hp tecumseh on a tiller that was acting really strange. I traced the problem to a worn lever in the linkage that was making it impossible for me to adjust it. Once I had that tightened up I was able to make the necessary adjustments and got it working properly. I hope it's not something internal!
#5 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted July 11, 2012 - 07:24 PM
The throttle shaft was bent at first causing it to stick. I got it straitened out and seems to turn well. Im pretty sure I checked the gear when I tore it down and know I would have addressed it if it was a problem. The cable is a little sticky so that may be a route I take. Maybe for now though, since it won't be doing much work, I'll set it at high idle and puts around slowly. Thanks for the thoughts.
