Cub Original Stopped Moving
11 replies to this topic
#1 NyRedNeck OFFLINE
NyRedNeck
  • 86 Thanks
  • 126 posts
Posted July 07, 2012 - 03:54 PM
Hey Guys,
I was mowing just fine the other day when the Cub came to a halt. Tranny seems to shift into all gears but the thing just will not move. I was running out of time and just put it away until further inspection.. any clues where I should start?
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted July 07, 2012 - 03:57 PM
Been a long time since owning a CC, but seems like there is a roll pin in the drive shaft next to the transaxle??? Anyways, just check to see that the input shaft of the transaxle is indeed turning. If not, something is sheared ahead of it. If the input shaft IS turning, then you have something internal gone wrong.
#3 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted July 07, 2012 - 04:14 PM
I agree with Daniel, I would check the drive shaft first. I hope it is nothing internal!
#4 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted July 07, 2012 - 04:23 PM
Make sure the belt is still on both ends and that the clutch is not bound up in any way. If the belt is on and the clutch is good then make sure that the flex coupler on the transmission has not come loose. If this all checks out then you have to move inside of the transimission and go from there.
  • olcowhand said thank you
#5 NyRedNeck OFFLINE
NyRedNeck
  • 86 Thanks
  • 126 posts
Posted July 07, 2012 - 04:27 PM
Thanks guys, will check these things out.
#6 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted July 07, 2012 - 05:33 PM
Never had an origonal, so once you said "belt", I had to pull up some pics. I didn't know there were belts in the drive on them! I just assumed they were like the 107's I owned. Learn something every day!
  • IHCubGuy said thank you
#7 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted July 07, 2012 - 06:13 PM
Yep the CCO is the only one that uses a belt.
Edited by Amigatec, July 07, 2012 - 06:14 PM.
#8 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted July 07, 2012 - 06:16 PM
Yepper they did. The funny thing is that the belt they used on the original for the drive is the same belt that they used for the starter generator belt on them.
#9 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted July 07, 2012 - 06:21 PM
That's partly right. The later model garden tractors that used the peerless transmission were belt drive as well. Models including the 1100, 482, 580, and 582S.
#10 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 27, 2012 - 03:31 AM
Did this get figured out?
#11 NyRedNeck OFFLINE
NyRedNeck
  • 86 Thanks
  • 126 posts
Posted July 30, 2012 - 08:05 PM
Not yet. I had to side line it for now. No time for fun and games :(
#12 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted August 01, 2012 - 06:28 PM
That is a bummer, let us know if you get back to it.
