Which One ?
9 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 07, 2012 - 08:54 AM
which end would be the best to use? i got a new to me steering rod and it came with the ends on it.
here is the ends that was on the ford when i got it.
and the one that came on the new steering rod
#2 KennyP OFFLINE
  • 41,027 Thanks
  • 47,165 posts
Posted July 07, 2012 - 09:28 AM
I'd use the ones that came with the rod. They are what is supposed to be on there!
#3 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 07, 2012 - 09:35 AM
Agreed!
#4 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted July 07, 2012 - 09:52 AM
I agree with these guys if you are trying to keep it original, if you don't care I would go with the new ones. If the old ones have a bolt that go through the spindle arm the hole will get bored out over time and you will get slop in your steering system. If you keep the new set-up you can just replace the tie rod ends when they get worn.
#5 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 07, 2012 - 09:57 AM
thanks
thats what i was thinking also but just wanted a second opinion
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 07, 2012 - 10:18 AM
For work I would use the tie rod end as it will have less friction and as Ryan said will likely be tighter than the used fitting. For a show tractor I'd stay original.
#7 olcowhand ONLINE
  • 42,902 Thanks
  • 31,943 posts
Posted July 07, 2012 - 04:03 PM
Someone just rigged up the pin style clevis joints. Much better with OE type.
#8 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted July 07, 2012 - 04:56 PM
Not to steel a thread, but those types of tie rod ends can be purchased from McMaster/Carr when a new one is needed.
http://www.mcmaster....od-ends/=ib2g77
#9 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted July 07, 2012 - 06:19 PM
that would be the same guy that cut the steering rod and welded it instead of just replacing it because it got bent. it was way to short so i had to get another one.
thanks for the link. saving it for later
#10 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted July 07, 2012 - 06:26 PM
I have one like that. Idiot welded the wrong ends and then drilled the holes out in the spindles to match the over sized holes in the tierod ends.
